I am at the moment implementing a QR Code scanning widget with the help of the github project HTML5 QR Code reader.
I am using the Eclipse Extension plugin and the Eclipse Extension sdk
How and where should external javascript and css files be referenced, I know that they should be kept in the ui folder, but I do not know where to reference them, the code i have found it this (append the script in the head):
$("head").append("<script type="text/javascript" src="../Common/Extensions/QRCodeExtension/ui/qrcode_widget/scanner2-core.js"></script>)
Kindly
Oskar Berntorp
You can mention external javascript reference in the metadata.xml file
/VR
Hi Velkumar,
I can see that your answer do not mention local javascript files, how should their url look?
// Oskar
You can mention custom js like this.
Place your files under folder ui > WIDGET NAME >
/VR
And to add to what @Velkumar stated, which is exactly what you need, you don't need to add in your runtime.js any import statement like the one you mentioned.
