How to Use Data Refreshed on time in mashup
LY_10691079
11-Garnet
Hi everyone,
I am getting data from from windchill and then storing it into thingworx locally so what I want is user should
have flexibility to refresh the data and it should also showing at the mashup UI like when the data refreshed last time like that so to achieve this what should I have to do
like what is happening in the background (Windchiil system) may be some data gets updated so in that case user want to see live data and the time when he refresh so what should I have to do implement this kind of problem
I am thinking of a scheduler which should be running after each specified time and also thinking to  give user flexibility to see the data refreshed  so how can I implement it
Lav
Rocko
(To:LY_10691079)
Well, 8.5 is a very old version, out of support for more than two years now. You should really consider upgrading.
If I am not mistaken, back then Auto-Reload was a widget, not a function, try to look there.
6 REPLIES 6
Rocko
(To:LY_10691079)
In a Mashup, under Functions, you find "Auto Refresh". Whenever there is an refresh event, you can call a Refresh service which gets the data from Windchill. You can also store the refresh time in a property or a session variable which is bound to a display widget. You can also add a manual "Refresh" button which calls the same service, for the inpatient users.
But you need to take into account that is is happening for all users opening the mashup, which might end up in too many queries to Windchill.
In that case you might want to use a timer to get data regularly from Windchill, cache the result, and all mashup display the cached data only. This way the number of requests to Windchill is independent on the number of viewers of a mashup.
A third more complex way would be to implement in Windchill to PUSH the data to Thingworx instead of TWX pulling it.
Hi @Rocko Thank you for you reply,
but in thingworx 8.5 we don't have auto refresh function so then how can I proceed?
regards,
lav.
Rocko
(To:LY_10691079)
Yup there is a widget called Auto Refresh but functionality is very limited in that not have much functionality or if you know then please let me know how to configure that
or Is there any other way can you propose?
thanks.
lav.
Rocko
(To:LY_10691079)
The widget should work the same way as the function. You configure it, and then it fires "Refresh" events regularly, In both versions, you bind the Refresh event then to your Service execution.
ok let me try
thanks.
