The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
How to alter the sequence in Responsive tabs in already developed mashup.
For Eg If need to change the sequence of A tab from 3rd Position to 5th Position Or I need to swap both the tabs.How to do the same ?
Is there any configuration settings in Thingworx composer in Resposive Tabs category.
I don't see a viable solution here. You may look into altering the tab widget or developing your own. Attaching documentation on custom extensibility.
Use Menu Widget Instead, and fill it dynamically with Data-Driven.
