How to alter the sequence in Responsive tabs in already developed mashup.
nshelke
For Eg If need to change the sequence of A tab from 3rd Position to 5th Position Or I need to swap both the tabs.How to do the same ?
Is there any configuration settings in Thingworx composer in Resposive Tabs category.
posipova
20-Turquoise
(To:nshelke)
I don't see a viable solution here. You may look into altering the tab widget or developing your own. Attaching documentation on custom extensibility.
Use Menu Widget Instead, and fill it dynamically with Data-Driven.
