How to build an independent project
Sri1
I am from web development field and am new to thingworx programming.
 - I can create things and mashups, but after that how do i build it as a whole project and run it separately (For eg: Like Manufacturing Apps.)
- How to navigate from one page(mash up) to another like in web application.
Thanks and regards,
Sri1
AndreaSteyn
(To:Sri1)
Hi @Sri1 ,
If I understand what you mean by "Project" correctly you create a project and you can link all the relevant things and templates to this. This is however mainly for exporting and importing a project with all the relevant templates etc.
Usually you create one main mashup from which you can navigate to different parts.  Per user you can specify that Thingworx opens on that mashup. This gives the impression similar to when you open manufacturing apps.
Regarding your question on navigation. There are different methods but you can start by using the navigation widget. This is a clickable image to navigate to another mash-up.
slangley
(To:Sri1)
Hi @Sri1.
Check out our Developer portal for training guides, etc. that can help to hi-light some possibilities.
--Sharon
slangley
(To:slangley)
Hi @Sri1.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.  Otherwise, please provide more detail around your question so we can assist.
--Sharon
