How to change scheduler's configuration through script
flucciarini
Hi guys,
I want to change scheduler's configuration through a script called in a subscription event.
For scheduler entity find only DisableScheduler and EnableScheduler method.
Is it possible to change scheduler's configuration at "runtime"?
Thank's to all
I find the problem
correct code below
var sch = Things["LightSwitchOn"];
var params = {
  tableName: "Settings" /* STRING */
var ext = sch.GetConfigurationTable(params);
var x = ext.getRow(0);
x.SetStringValue("schedule", "0 " + cronDate.getMinutes() + " " + cronDate.getHours() + " * * ? *");
x.SetBooleanValue("enabled", true);
x.SetStringValue("runAsUser", "Administrator");
var paramsSet = {
  configurationTable: ext /* INFOTABLE */,
  persistent: true /* BOOLEAN */,
// no return
sch.SetConfigurationTable(paramsSet);
sch.EnableThing();
logger.info("Controllo configurazione restart LightSwitchOn");
sch.RestartThing();
Thanks Ankit for java solution
ankigupta
(To:flucciarini)
Hi Fabrizio Lucciarini​,
We have option to set the Configuration by using the service SetConfigurationTable.
After running the service you will have to call RestartThing Service to run it with the new configuration.
I had written following Java Code to update the configuration sometime back. You can write a similar code in JavaScript.
Thing sch = ThingUtilities.findThing("SchedulerXXX");
        InfoTable ext = sch.getConfigurationTable("Settings");
        ValueCollection x = ext.getRow(0);
        x.SetStringValue("schedule", "0/10 * * * * ? *");
        sch.SetConfigurationTable("Settings", ext, true);
        sch.EnableThing();
        sch.RestartThing();
I hope it helps.
flucciarini
(To:ankigupta)
I write in javascript the code below
var ext = sch.getConfigurationTable("Settings");
sch.EnableThing();
sch.RestartThing();
but I get the following error
TypeError: Cannot find function getConfigurationTable in object com.thingworx.things.scheduler.SchedulerThing@36edb26b. (ScheduledEvent#18)
I find the problem
correct code below
var params = {
var paramsSet = {
// no return
sch.EnableThing();
sch.RestartThing();
ankigupta
(To:flucciarini)
Try using GetConfigurationTable.
