We have created the chartline graph where we need to change the tooltip according to xaxis and yaxis.
I need the YValue to be changed to FFT_Data.
Expecting the answer ASAP.
Attached the image for reference.
Hi @PG_10250187.
In the ValuesTooltip, try replacing the default token (${label}, ${series}: ${value}) with this string: ${label}, FFT_Data: ${value}. This may not make sense if you have multiple data series.
--Sharon
Hi @PG_10250187.
--Sharon
