How to create and show a region on google map widget
fmanniti
I am quite sure I can find an example somewhere in the support but I looked for without success.
I want to create an area by clicking locations on google map widget and that this area is visible on the map.
I've seen there is the possibility to bind a region but maybe I'm doing something wrong.
I have a ThingTemplate with 10 things, each thing has a location property, I want those 10 locations set a region.
If I load the GetImplementingThingsWithData service and bind AllData to RegionData, I can't see my region.
Another thing I would like to do is make the user define a new region by clicking a certain number of points on the map which will set the perimeter of the area.
Is there anyone who could explain me this? Or also could give me a link with a document I can read?
aduarte
(To:fmanniti)
For your first question, take a look at this: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS225480
I hope that this can help you.
6 REPLIES 6
aduarte
(To:fmanniti)
Thank you very much. It's what I needed.
Just another question:
what if I want to show only one region?
I mean, I have a thing template which has one infotable property called "perimeter". To show them all I must bind "All data" from GetImplementhingThingsWithData to RegionData and SelectedRow(s)->perimeter->SelectedRow(s) to RegionLocationData.
But if I would only show the region for the selected entity I do the same thing  but instead bind "All data" to RegionData, I would bind "SelectedRow(s)".
My problem is that my google widget is inside a gadget and the list with all entities is out the gadget. Is it possible to do this?
aduarte
(To:fmanniti)
Hello Fabio,
When you say that you have your google widget inside a gadget, you mean that you have it inside a mashup and your list with all entities in an other mashup?
Yes indeed.
I have what follows:
Main mashup
  • List widget (A list of all my entities)
  • Dashboard - A dashboard which contains several gadgets
    • Map gadget (with the google map)
So I'd like that the selected entity in the list widget may "speak" with the region in the map inside the gadget
aduarte
(To:fmanniti)
I'm sorry Fabio, i've never worked with dashboards, i don't know how you can pass to your map gadget the thingname of your entity.
I hope that someone else can help.
Ana.
