How to add "Button" in the column of grid?
  • January 2, 2017
  • 2 replies
  • 5805 views
I want to add a "Button" in the specific column of a "Grid" for every row.
Also that button should be toggle button (That is if that button has text 'On' & after click text should changed to 'Off' and vise-versa).
How do I achieve this functionality?
I am using Thingworx version 6.0 .
Thanks & Regards,
Rupesh
Hi Rupesh,
You can't with Grid Widget, if you want to have this kind of interaction you should use Repeater Widget instead.
Carles.
rmote1-VisitorAuthor
Hi Carles,
Thanks for your reply !
Can we add check box in the grid instead of button?
If yes, how ?
And how can I handle particular functionality on the check/uncheck event of check box?
Rupesh
Hi Rupesh, again use Repeater Widget to do this kind of interaction.
20-Turquoise
January 10, 2017
Buttons in a grid column feature has been submitted as an enhancement request, PSPT-3236.
Thanks Polina
