I want live streaming of ip camera in thingworx
I have one ip camera which will supports RTSP protocol. It will send the stream to the RTSP server.
But how we can connect thingworx to the RTSP server?
How can thingworx will communicate with RTSP server?
How to play live stream in thingworx mashup?
HTML5 widget support .mp4 and .m3u8 files for streaming so how we can convert RTSP stream to .mp4 file
Or
If camera will send the stream to HLS protocol should thingworx will inetgrate with HLS server?
So many question are there how thingworx will achieve this?
Please suggest a right way.
Hi @DT_9697337.
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
