How to get the value centered in Value Display widget
NN_10375125
There is no option  available that i can the height of the value centered do someone know another way to solve this ?
8 REPLIES 8
PaiChung
22-Sapphire I
(To:NN_10375125)
Does the widget have a property called 'padding' you should be able to use that if it has it.
NN_10375125
(To:PaiChung)
Sadly there is no property called padding in the value display .
PaiChung
22-Sapphire I
(To:NN_10375125)
Then you would have to do it in CSS probably.
NN_10375125
(To:PaiChung)
Do you have an example code for me?
@NN_10375125
There should be a vertical alignment property you can use:
NN_10375125
(To:nmilleson)
no listed property called vertical alignment
NN_10375125
(To:nmilleson)
For any reason there is just horizontal alignment but no vertical
slangley
(To:NN_10375125)
Hi @NN_10375125.
Which version of ThingWorx are you running?
--Sharon
