There is no option available that i can the height of the value centered do someone know another way to solve this ?
Does the widget have a property called 'padding' you should be able to use that if it has it.
Sadly there is no property called padding in the value display .
Then you would have to do it in CSS probably.
no listed property called vertical alignment
For any reason there is just horizontal alignment but no vertical
Hi @NN_10375125.
Which version of ThingWorx are you running?
--Sharon
