How to programmatically set tags to recent entities?
EM_9923519
Hello, I want to tag with "Recent tag" the last modified entities I have used
How to do this using a script?
What I was thinking is
query all entities and if they have been used inside a date range, then execute a service to tag them
Please share some sample code to accomplish this task.
abjain
(To:EM_9923519)
@EM_9923519 : You can try using SpotlightSearch service which is present inside SearchFunctions resource .It gives list of all entities along with last modified date. This service can be used inside your custom service where you can provide date range and can also sort by lastmodifieddate with ascending or descending order. Please also refer this article: https://www.ptc.com/en/support/article/CS180125
2 REPLIES 2
abjain
(To:EM_9923519)
abjain
(To:abjain)
@EM_9923519 :If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
