How to query infotable to check given column is between specified date values?
nbhagtani
I have got infotable and i need to check that any column(having date value) is between specified start and end date. I tried one sample but it gives me error :
" Wrapped org.json.JSONException: JSONObject["type"] not found. Cause: JSONObject["type"] not found."
below is the code i tried:
var query = {
   "filters": {
          //type: "OR",
          "filters": [
            "fieldName": "Temperature",
            "type": "BETWEEN",
            "from": startDate,
            "to": endDate
            "fieldName": "Humidity",
            "type": "BETWEEN",
            "from": startDate,
            "to": endDate
var recordsToDisplay = Resources['InfoTableFunctions'].Query(
        query : query,
        t : requiredRows
Please help me where i am going wrong.
Hi Nisha,
I think you have two undesired slashes // in front of type: "OR".
Also type should be "type".
And one last thing, inner "filters" parameter content it's an array, then you should set it's conent with [ ] instead of { }.
You should have something like this:
var query = {
  "filters": {
    "type": "OR",
    "filters": [
        "type": "BETWEEN",
        "from": startDate,
        "to": endDate
        "type": "BETWEEN",
        "from": startDate,
        "to": endDate
CRArko
(To:nbhagtani)
Hello, Nisha.
The closest I've been able to find to what you're asking for is in:
Query Infotable
It talks about using the Query() InfoTableFunction in the Snippets tab to make the query on the InfoTable. Let me try this and see if I can find what's missing.
-- Craig A.
Hi Nisha,
var query = {
  "filters": {
    "type": "OR",
    "filters": [
        "type": "BETWEEN",
        "from": startDate,
        "to": endDate
        "type": "BETWEEN",
        "from": startDate,
        "to": endDate
Thanks Carles it worked.
