The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
hi
i work with ATE on win10 via docker.
today i tried to get familir with the application,and i use some test data to create a model.
but after i click generate Profiles and Signals, the application got stuck,and i can't enter the composer with the browser.
i finally entered it again after the docker and sever restart. but the job sate remains RUNNING, over half an hour,it is still RUNNING.
i try to create a new job, but it shows that the new job was in queue.
how can i remove the RUNNING job?
Please help
Thank in advance
Minnan
You TWA version must be earlier than 8.3 to accept multi-task.
Please try if this could work (copied from a 8.3 article, not sure if things changed.):
As a workaround to remove the running job
hi
i try to search AnalyticsServer_DataThing in the composer.but i can't find it.
is it there is no that thing in the version 8.2?
Kind regards
Minnan
Hi @MinNan
Could you try to find *DataThing
May be the suffix of this Thing is different. But it should end with DataThing.
Mohit
