How to remove extra space in dynamic panel widget
Velkumar
Hello all,
Does anyone know how to remove this extra space in dynamic panel ?
TonyZhang
(To:Velkumar)
Hi @Velkumar,
Depending on your ThingWorx Platform version, the following CSS might not work, but have a try adding below code to your Mashup's CustomCSS
ptcs-dynamic-panel::part(panel-wrapper) {
    position: unset;
Tony
TonyZhang
(To:Velkumar)
Hi @Velkumar,
    position: unset;
Tony
Velkumar
(To:TonyZhang)
It worked on 9.0!
Thank you
I have given AnchorLocation: Left. When i added this css code, the space on the left side panel disappeared. But in my case, the space on right side of panel should be disappeared. What should i alter in this css code?
Velkumar
(To:AP_9587236)
Actually this CSS makes all side to disappear not particular to left or right
