How to see Java Codes which is imported to thingworx as services ?
Hi @AP_9587236
Before I answer, as a side note, what you asked for is known as "Java source code" in programming circles.
To answer your question, it depends on who built the extension you imported:
If you encounter any issue with PTC built extensions, assuming you read the documentation and have attended a certain level of training, I suggest raising a bug on the support portal, support.ptc.com
Hi, have you imported a custom Extension to Thingworx? Could you describe what kind of import did you perform?
I can see a service like this in thing. How to view its code ?
Hi @AP_9587236
