How to see Java Codes which is imported to thingworx as services ?
AP_9587236
Hi @AP_9587236
Before I answer, as a side note, what you asked for is known as "Java source code" in programming circles.
To answer your question, it depends on who built the extension you imported:
  • if it's built by PTC, you are not allowed to do this, as described in the licensing terms, here.
  • if it's built by another company/partner, you can always ask them for the source code, depending of course on the terms of your contract with them.
If you encounter any issue with PTC built extensions, assuming you read the documentation and have attended a certain level of training, I suggest raising a bug on the support portal, support.ptc.com
3 REPLIES 3
Hi, have you imported a custom Extension to Thingworx? Could you describe what kind of import did you perform?
I can see a service like this in thing. How to view its code ?
Hi @AP_9587236
