The default Max Fields value is 25, which is not enough for time series model. How to set this parameter when creating time series model?
Let's say, my dataset has 15 fields, including one entity_id filed and one temporal field. When I set lookback to 16, UseGoladHistory to false, then how to set the Max Fields?
Hi @zhuwenxi
Apologies, I misunderstood your request.
In this case I think the Help Center page Time Series Predictions will have some relevant information, look specifically at the history-pivoted data mentioned.
Kind regards
Christophe
Hi @zhuwenxi
If you are using Builder, when creating the model under Advanced Model Configuration tab, you do have a field for Max Fields.
If using the CreateJob() service from TrainingThing , you do have a parameter
When building a time series model, Analytics will generate many fields, the default MaxFields 25 is not enough ,and will ignore many fields. I just want to know is there a way to evaluate how many fields will be used. What I do now is set MaxFields to a bigger enough value.
Hi @zhuwenxi
Kind regards
Christophe
Hi @zhuwenxi.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question. If you still need assistance, please let us know.
--Sharon
