How to synchronize mashups without autorefresh, using iframe?
  • April 5, 2018
  • 2806 views
I need 2 mashups to be synchronized, with real-time response since both will share data.
So far, all right since I can have the data in a Thing, and use the services "GetProperties" and "SetProperties". With the "GetProperties" I use the checkbox "Automatically update values when able" and everything works perfectly in 2 tab / browsers.
My problem arises when I try to show it with iframe.
With iframe does not refresh the data, I need to use an auto-refresh to search the data.
I have annotated all ClickjackFilter.
Is it a version problem?
Is it a problem because "Automatically update values when able" is not compatible with iframe?
I'm using Thingworx 7.3.1 with PTC Navigate 1.6
22-Sapphire I
April 5, 2018
Potentially a websockets connection can't be made when functioning in the iframe.
But how come you have to use the iframe? are you showing a mashup in another system?
If it is based on some selection in the parent, you could potentially pass mashup parameters.
Hi @PaiChung
I am using iframe because I need to show some mashups embedded in my web page. Show fragmented (at least try) a mashup already created, the problem is that I can not synchronize.
I'm trying a very basic example, just a "Textarea" and a "Value Display". When modifying the Textarea, I would like it to be shown in the "Value Display", not only in the instance in which I modified the Textarea, but also to show the value in any previously loaded view.
