How to use cluster Microservice in ThingWorx Analytics
sarathi
Please give some tutorial how to use clusters microservieces
cmorfin
(To:sarathi)
Hi @sarathi
Doing some more digging into this and it appears that the cluster functionality is currently rather limited .
It allows to create a pmml model but unless you can use this pmml model in some other software, y ou won't be able to do much with it in current release.
See https://www.ptc.com/en/support/article?n=CS286900
Kind regards
Christophe
7 REPLIES 7
mgoel
(To:sarathi)
Hi @sarathi
https://community.ptc.com/t5/IoT-Tech-Tips/ThingWorx-Analytics-Server-Microservices-and-their-Functions/m-p/549208#M998%3F&posno=2&q=clustering%20microservice&source=search
See this for functionality of microservices. You can run and test some of services of Clustering micro service from TWX and check what they return for a particular instance.
You can find this by suffix _ClusteringThing, Do let me know in case of any question.
Mohit
sarathi
(To:mgoel)
Hi @mgoel
Already i created datasets from analytics builder and created job from clustering Microservice it returned Jobid,
When i retrived Jobid results, It will return one Model as an xml file,
 after that i dont know how to  do that........is there any documentation available for clustering from datasets
I want to know the step by step tutorial for how to create cluster from datasets.
cmorfin
(To:sarathi)
Hi @sarathi
Kind regards
Christophe
Hi how to generate above mentioned PMML file.I had other software to use this PMML file.I created a sample dataset in analytics builder.I have no any idea above about analytics manager.It will be helpful if you explain in detail to generate PMML file.
Thank you
cmorfin
(To:user539)
I uploaded dataset in builder.Can you explain in detail how to generate xml file from clustering micro service.It will be more helpful if explained in step wise step.
cmorfin
(To:user539)
