Please give some tutorial how to use clusters microservieces
Hi @sarathi
Doing some more digging into this and it appears that the cluster functionality is currently rather limited .
It allows to create a pmml model but unless you can use this pmml model in some other software, y ou won't be able to do much with it in current release.
See https://www.ptc.com/en/support/article?n=CS286900
Kind regards
Christophe
Hi @sarathi
See this for functionality of microservices. You can run and test some of services of Clustering micro service from TWX and check what they return for a particular instance.
You can find this by suffix _ClusteringThing, Do let me know in case of any question.
Mohit
Hi @mgoel
Already i created datasets from analytics builder and created job from clustering Microservice it returned Jobid,
When i retrived Jobid results, It will return one Model as an xml file,
after that i dont know how to do that........is there any documentation available for clustering from datasets
I want to know the step by step tutorial for how to create cluster from datasets.
Hi @sarathi
Kind regards
Christophe
Hi how to generate above mentioned PMML file.I had other software to use this PMML file.I created a sample dataset in analytics builder.I have no any idea above about analytics manager.It will be helpful if you explain in detail to generate PMML file.
Thank you
Just for the record this has been answered at https://community.ptc.com/t5/ThingWorx-Developers/How-to-generate-a-pmml-file-from-Thingworx-analytics-server/m-p/569461#M30781
I uploaded dataset in builder.Can you explain in detail how to generate xml file from clustering micro service.It will be more helpful if explained in step wise step.
For the record see https://community.ptc.com/t5/ThingWorx-Developers/PMML-using-clustering-microservive/m-p/572899/highlight/false#M31142 for this above question
