How to use google maps libraries like Drawing Library, Geometry Library and Places Library ?
done11
Hi all,
Does anyone know how to use google maps libraries like drawing library , geometry library and places library in google maps widget in thingworx ?
8 REPLIES 8
ttielebein
(To:done11)
There is a section of the Custom Extension Development Guide that talks about using custom widgets, and about using third party libraries in custom widgets.
Hope this helps!
aduarte
(To:done11)
On the metadata.xml you can replace:
<FileResource description="" isRuntime="true" isDevelopment="false" type="JS" url="https://maps.google.com/maps/api/js?sensor=false"/>
By:
<FileResource type="JS" url="https://maps.google.com/maps/api/js?sensor=false&amp;libraries=drawing,geometry"
  description="" isDevelopment="false" isRuntime="true" />
I hope this can help you.
done11
(To:aduarte)
Hi Ana,
Thanks for your help.
I have updated the metadata.xml file as you said.
But how to use that in the map ? I am unable to use it .
aduarte
(To:done11)
I added another data source to save the shapes and i call the function that i use to add the drawing option at the updateProperty.
But I think that you can added the code that you need at the afterRender, after having the map:
      this.map = new google.maps.Map(document.getElementById(this.jqElementId), options);
var polyOptions = {
  strokeOpacity: 0.9,
  strokeWeight: 2,
  strokeColor: zoneColor,
  fillOpacity: 0.50,
  fillColor: zoneColor,
  editable: true,
  draggable: true
drawingManager = new google.maps.drawing.DrawingManager({
  drawingControl: true,
  drawingControlOptions: {
   position: google.maps.ControlPosition.TOP_CENTER,
   drawingModes: [
         google.maps.drawing.OverlayType.CIRCLE,
         google.maps.drawing.OverlayType.POLYGON
  polygonOptions: polyOptions,
  circleOptions: polyOptions
drawingManager.setMap(this.map);
drawingManager is declared as global variable.
For my case, i just want to give the option to draw polygons and circles.
This is only for drawing the shapes.
I hope this can help you,
drawingManager
done11
(To:aduarte)
Hi Ana,
I tried the above steps as you said but still I can't see the drawing options available at the top of the map.
Can you please help regarding this ?
aduarte
(To:done11)
   Of course, can you send me your code please?
done11
(To:aduarte)
TW.Runtime.Widgets.googlemap = function () {
    var infoWindow = undefined;
  var drawingManager = undefined;
  var userHasPannedOrZoomedSinceAutoZoom = false;
  var initialData = true;
  var weAreChangingBounds = false;
  var autoZoomBehavior = 'every-data-change';
    var regionInfoWindow = undefined;
    var lastRegionNumber = undefined;
    var lastData = undefined;
    var lastRegionData = undefined;
    var infoId = 'MapInfoWindow' + TW.uniqueId();
    var tooltipMashupWidth = 100;
    var tooltipMashupHeight = 100;
    var isMashupTooltipConfigured = false;
    var isRegionTooltipConfigured = false;
    var dataInfotable = undefined;
    this.runtimeProperties = function () {
        return {
         'supportsAutoResize': true,
            'needsDataLoadingAndError': true,
            'propertyAttributes': {
                'TooltipLabel1': {'isLocalizable': true},
                'TooltipLabel2': {'isLocalizable': true},
                'TooltipLabel3': {'isLocalizable': true},
                'TooltipLabel4': {'isLocalizable': true},
                'RegionTooltipLabel1': {'isLocalizable': true},
                'RegionTooltipLabel2': {'isLocalizable': true},
                'RegionTooltipLabel3': {'isLocalizable': true},
                'RegionTooltipLabel4': {'isLocalizable': true}
  this.resize = function(width,height) {
  try {
            google.maps.event.trigger(this.map, 'resize');
  } catch(err) {}
    this.renderHtml = function () {
        tooltipMashupWidth = thisWidget.getProperty('TooltipMashupWidth');
        tooltipMashupHeight = thisWidget.getProperty('TooltipMashupHeight');
     var oldAutoZoom = this.getProperty('AutoZoom');
     autoZoomBehavior =  this.getProperty('AutoZoomBehavior');
     switch( autoZoomBehavior ) {
     case 'disable-on-user-pan-zoom':
     case 'only-when-autozoom-invoked':
         case 'only-initial-data':
     // leave these alone
     break;
     default:
     // anything else, default to our old behavior
     if( oldAutoZoom === undefined || oldAutoZoom === true )  {
     } else if( oldAutoZoom === false ) {
     autoZoomBehavior = 'only-when-autozoom-invoked';
     } else {
     break;
        var mashupName = thisWidget.getProperty('TooltipMashupName');
        if (mashupName !== undefined && mashupName.length > 0) {
            isMashupTooltipConfigured = true;
        try {
            if (google !== undefined && google !== null) {
                this.haveGoogleMaps = true;
        catch (errmsg) {
        if (this.haveGoogleMaps)
            return '<div class="widget-content widget-map-runtime"></div>';
        else
            return '<div class="widget-content widget-map-runtime"><span class="textsize-large">Google Maps Are Not Available</span></div>';
    var thisWidget = this;
    this.haveGoogleMaps = false;
    this.ignoreSelectionEvent = false;
    this.ignoreRegionSelectionEvent = false;
    this.map = undefined;
    this.selectionMarker = null;
    this.startMarker = null;
    this.endMarker = null;
    this.polyline = null;
    this.routePolyline = null;
    this.plannedRoutePolyline = null;
    this.dataBounds;
    this.plannedRouteDataBounds;
    this.routeDataBounds;
    this.regionDataBounds;
    this.lastBounds;
    this.lastZoom;
    this.markerLookup = new Array();
    this.currentMarkers = new Array();
    this.selectedRows = new Array();
    this.currentRegions = new Array();
    this.selectedRegionRows = new Array();
    this.markerStyle;
    this.selectedMarkerStyle;
    this.selectionMarkerStyle;
    this.startMarkerStyle;
    this.endMarkerStyle;
    this.pathStyle;
    this.routeStyle;
    this.plannedRouteStyle;
    this.regionStyle;
    this.afterRender = function () {
        this.markerStyle = TW.getStyleFromStyleDefinition(this.getProperty('MarkerStyle'));
        this.selectionMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectionMarkerStyle'));
        this.selectedMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectedMarkerStyle'));
        this.startMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('StartMarkerStyle'));
        this.endMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('EndMarkerStyle'));
        this.pathStyle = TW.getStyleFromStyleDefinition(this.getProperty('PathStyle'));
        this.plannedRouteStyle = TW.getStyleFromStyleDefinition(this.getProperty('PlannedRouteStyle'));
        this.routeStyle = TW.getStyleFromStyleDefinition(this.getProperty('RouteStyle'));
        this.regionStyle = TW.getStyleFromStyleDefinition(this.getProperty('RegionStyle'));
        this.selectedRegionStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectedRegionStyle'));
        if (this.haveGoogleMaps) {
            var zoom = parseInt(this.getProperty('Zoom'));
            var centerPosition = new google.maps.LatLng(TW.clientPosition.coords.latitude, TW.clientPosition.coords.longitude);
            if (this.getProperty('SelectedLocation') !== undefined) {
                centerPosition = new google.maps.LatLng(this.getProperty('SelectedLocation').latitude, this.getProperty('SelectedLocation').longitude);
            var options = {
                zoom: zoom,
                center: centerPosition,
                mapTypeId: this.getProperty('MapType')
         switch( this.getProperty('MapSkin','normal') ) {
         case 'normal':
         break;
         case 'blue':
         options['styles'] = [{"featureType":"water","elementType":"geometry","stylers":[{"color":"#193341"}]},{"featureType":"landscape","elementType":"geometry","stylers":[{"color":"#2c5a71"}]},{"featureType":"road","elementType":"geometry","stylers":[{"color":"#29768a"},{"lightness":-37}]},{"featureType":"poi","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"featureType":"transit","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"elementType":"labels.text.stroke","stylers":[{"visibility":"on"},{"color":"#3e606f"},{"weight":2},{"gamma":0.84}]},{"elementType":"labels.text.fill","stylers":[{"color":"#ffffff"}]},{"featureType":"administrative","elementType":"geometry","stylers":[{"weight":0.6},{"color":"#1a3541"}]},{"elementType":"labels.icon","stylers":[{"visibility":"off"}]},{"featureType":"poi.park","elementType":"geometry","stylers":[{"color":"#2c5a71"}]}];
         break;
         case 'gray':
         options['styles'] = [{"featureType":"landscape","stylers":[{"saturation":-100},{"lightness":65},{"visibility":"on"}]},{"featureType":"poi","stylers":[{"saturation":-100},{"lightness":51},{"visibility":"simplified"}]},{"featureType":"road.highway","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"road.arterial","stylers":[{"saturation":-100},{"lightness":30},{"visibility":"on"}]},{"featureType":"road.local","stylers":[{"saturation":-100},{"lightness":40},{"visibility":"on"}]},{"featureType":"transit","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"administrative.province","stylers":[{"visibility":"off"}]},{"featureType":"water","elementType":"labels","stylers":[{"visibility":"on"},{"lightness":-25},{"saturation":-100}]},{"featureType":"water","elementType":"geometry","stylers":[{"hue":"#ffff00"},{"lightness":-25},{"saturation":-97}]}];
  break;
            if (this.getProperty('EnableLocationSelection')) {
                options["disableDoubleClickZoom"] = true;
            else {
                options["disableDoubleClickZoom"] = false;
            //if (TW.Runtime.globalMap === undefined) {
            //    $('body').append(
            //                '<div id="global-map" style="top:0px;left:0px;width:200px;height:200px;">' +
            //                '</div>');
            //    TW.Runtime.globalMap = new google.maps.Map(document.getElementById('global-map'), options);
            //this.map = TW.Runtime.globalMap;
            //this.jqElement.append($('#global-map'));
            //$('#global-map').show().css('height', this.getProperty('Height') + 'px').css('width', this.getProperty('Width') + 'px');
  var polyOptions = {
   strokeOpacity: 0.9,
   strokeWeight: 2,
   fillOpacity: 0.50,
   editable: true,
   draggable: true
    drawingModes: [
            infoWindow = new google.maps.InfoWindow();
            regionInfoWindow = new google.maps.InfoWindow();
            if(this.getProperty('ShowTraffic')) {
                this.trafficLayer = new google.maps.TrafficLayer();
                this.trafficLayer.setMap(this.map);
            google.maps.event.addListener(this.map, 'idle', function (event) {
            var bounds = thisWidget.map.getBounds();
            var changed = false;
            if(thisWidget.lastBounds !== undefined) {
            if(thisWidget.lastBounds.getNorthEast().lat() != bounds.getNorthEast().lat())
            changed = true;
            if(thisWidget.lastBounds.getNorthEast().lng() != bounds.getNorthEast().lng())
            changed = true;
            if(thisWidget.lastBounds.getSouthWest().lat() != bounds.getSouthWest().lat())
            changed = true;
            if(thisWidget.lastBounds.getSouthWest().lng() != bounds.getSouthWest().lng())
            changed = true;
            else {
            changed = true;
            if(changed) {
             // ignore this if it's just getting the initial bearings
             if( thisWidget.lastBounds !== undefined ) {
             if( !weAreChangingBounds ) {
             userHasPannedOrZoomedSinceAutoZoom = true;
                    var nelocation = new Object();
                    nelocation.units = "WGS84";
                    nelocation.elevation = 0.0;
                    nelocation.latitude = bounds.getNorthEast().lat();
                    nelocation.longitude = bounds.getNorthEast().lng();
                    thisWidget.setProperty('NEBoundary', nelocation);
                    var swlocation = new Object();
                    swlocation.units = "WGS84";
                    swlocation.elevation = 0.0;
                    swlocation.latitude = bounds.getSouthWest().lat();
                    swlocation.longitude = bounds.getSouthWest().lng();
                    thisWidget.setProperty('SWBoundary', swlocation);
                    nelocation.latitude = bounds.getSouthWest().lat();
                    thisWidget.setProperty('SEBoundary', nelocation);
                    swlocation.latitude = bounds.getNorthEast().lat();
                    thisWidget.setProperty('NWBoundary', swlocation);
                    thisWidget.lastBounds = bounds;
                    thisWidget.jqElement.triggerHandler('BoundsChanged');
            var zoomChanged = false;
            var currentZoom = thisWidget.map.getZoom();
            if(thisWidget.lastZoom !== undefined) {
            if(thisWidget.lastZoom != currentZoom)
            zooomChanged = true;
            else {
            zoomChanged = true;
            if(zoomChanged) {
                    thisWidget.setProperty('CurrentZoom', currentZoom);
                    thisWidget.lastZoom = currentZoom;
                if (this.getProperty('ShowSelectionMarker') === true) {
                    this.selectionMarker = new google.maps.Marker({
                        map: this.map,
                        position: centerPosition,
                        title: "Selection",
                        icon: this.selectionMarkerStyle.image
                    this.selectionMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 3);
                google.maps.event.addListener(this.map, 'dblclick', function (event) {
                    var location = new Object();
                    location.latitude = event.latLng.lat();
                    location.longitude = event.latLng.lng();
                    thisWidget.moveSelectionMarker(location);
                    thisWidget.setProperty('SelectedLocation', location);
                    thisWidget.jqElement.triggerHandler('Changed');
             weAreChangingBounds = true;
                this.map.setZoom(this.map.getZoom() - 1);
                this.map.setZoom(this.map.getZoom() + 1);
    this.moveSelectionMarker = function (newLocation) {
            if (newLocation !== undefined) {
                var latlng = new google.maps.LatLng(newLocation.latitude, newLocation.longitude);
                    if (this.selectionMarker !== null) {
                        this.selectionMarker.setMap(this.map);
                    this.selectionMarker.setPosition(latlng);
                    } else {
                         position: latlng,
                         map: this.map,
                         title: "Selection",
                this.map.setCenter(latlng);
    this.clearSelectedRegions = function () {
        thisWidget.selectedRegionRows = [];
        for (var regionNo = 0; regionNo < thisWidget.currentRegions.length; regionNo++) {
            var currentRegion = thisWidget.currentRegions[regionNo];
            currentRegion.setOptions( { fillColor: currentRegion._assignedFillColor, strokeColor : currentRegion._assignedStrokeColor, strokeWeight : currentRegion._assignedStrokeWeight });
            currentRegion._isSelected = false;
    this.clearSelectedMarkers = function () {
        thisWidget.selectedRows = [];
        for (var markerNo = 0; markerNo < thisWidget.currentMarkers.length; markerNo++) {
            var currentMarker = thisWidget.currentMarkers[markerNo];
            currentMarker._isSelected = false;
            currentMarker.setIcon(currentMarker._assignedIcon);
            currentMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
    this.setSelectedMarker = function (selectedRow) {
        var isMultiselect = thisWidget.properties['MultiSelect'];
        var selectedMarker;
            if (currentMarker.rowNumber === selectedRow) {
                selectedMarker = currentMarker;
                break;
        if (selectedMarker !== undefined) {
            if (selectedMarker._isSelected) {
                if (isMultiselect) {
                    TW.removeElementFromArray(thisWidget.selectedRows, selectedRow);
                    selectedMarker._isSelected = false;
                    selectedMarker.setIcon(selectedMarker._assignedIcon);
                    selectedMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
                    if (!thisWidget.ignoreSelectionEvent) {
                        thisWidget.updateSelection('Data', thisWidget.selectedRows);
            else {
                if (!isMultiselect) {
                    thisWidget.clearSelectedMarkers();
                    thisWidget.selectedRows = [selectedRow];
                else
                    thisWidget.selectedRows.push(selectedRow);
                selectedMarker.setIcon(thisWidget.selectedMarkerStyle.image);
                selectedMarker._isSelected = true;
                selectedMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
    this.setSelectedRegion = function (selectedRow) {
        var isMultiselect = thisWidget.properties['RegionMultiSelect'];
        var selectedRegion;
            if (currentRegion.rowNumber === selectedRow) {
                selectedRegion = currentRegion;
                break;
        if (selectedRegion !== undefined) {
            if (selectedRegion._isSelected) {
                    TW.removeElementFromArray(thisWidget.selectedRegionRows, selectedRow);
                    selectedRegion._isSelected = false;
                    selectedRegion.setOptions( { fillColor: selectedRegion._assignedFillColor, strokeColor : selectedRegion._assignedStrokeColor, strokeWeight : selectedRegion._assignedStrokeWeight });
                    if (!thisWidget.ignoreRegionSelectionEvent) {
                        thisWidget.updateSelection('RegionData', thisWidget.selectedRegionRows);
            else {
                    thisWidget.clearSelectedRegions();
                    thisWidget.selectedRegionRows = [selectedRow];
                else
                    thisWidget.selectedRegionRows.push(selectedRow);
                selectedRegion._isSelected = true;
                selectedRegion.setOptions( { fillColor: thisWidget.selectedRegionStyle.backgroundColor, strokeColor : thisWidget.selectedRegionStyle.lineColor, strokeWeight : parseInt(thisWidget.selectedRegionStyle.lineThickness) });
    this.handleSelectionUpdate = function (propertyName, selectedRows, selectedRowIndices) {
        if (propertyName == "Data") {
            thisWidget.ignoreSelectionEvent = true;
            var nSelectedRows = selectedRowIndices.length;
            for (var selectedRowIndex = 0; selectedRowIndex < nSelectedRows;selectedRowIndex++) {
                thisWidget.setSelectedMarker(selectedRowIndices[selectedRowIndex]);
            thisWidget.ignoreSelectionEvent = false;
        if (propertyName == "RegionData") {
            thisWidget.ignoreRegionSelectionEvent = true;
                thisWidget.setSelectedRegion(selectedRowIndices[selectedRowIndex]);
            thisWidget.ignoreRegionSelectionEvent = false;
    this.mouseOverEventListener = function (e) {
        var latlng = e.latLng;
        if (!isMashupTooltipConfigured) {
            return;
        var markerCount = thisWidget.markerLookup.length;
        for (var i = 0; i < markerCount; i++) {
            var markerInfo = thisWidget.markerLookup;
            if (latlng.lat() == markerInfo.latlng.lat() && latlng.lng() == markerInfo.latlng.lng()) {
                var selectedMarker = markerInfo.marker;
                var selectedRowNo = selectedMarker.rowNumber;
                TW.log.info('Should display info for Row #' + selectedRowNo);
                //thisWidget.setSelectedMarker(selectedRowNo);
                thisWidget.cleanupTooltipMashup();
                infoWindow.setContent('<div id="' + infoId + '" style="width:' + tooltipMashupWidth + 'px;height:' + tooltipMashupHeight + 'px;">Loading Tooltip Mashup...</div>');
                //infoWindow.setContent('<div id="' + infoId + '" style="">Hello there, selected Row #' + selectedRowNo + ', "' + lastData[selectedRowNo]['name'] + '"</div>');
                //infoWindow.setContent('Hello there, selected Row #' + selectedRowNo + '');
                infoWindow.setPosition(markerInfo.latlng);
                infoWindow.open(this.map, markerInfo.marker);
                setTimeout(function () {
                    var mashupSpec = {};
                    mashupSpec.mashupName = thisWidget.getProperty('TooltipMashupName');
                    mashupSpec.mashupParameters = {};
                    var mashupParameters = thisWidget.properties['MashupParameters'];
                    if (mashupParameters === undefined)
                        mashupParameters = [];
                    var nParams = mashupParameters.length;
                    for (var paramNo = 0; paramNo < nParams; paramNo++) {
                        var paramInfo = mashupParameters[paramNo],
                            propName = paramInfo.ParameterName,
                            fldName = thisWidget.getProperty(propName),
                            propValue;
                        if (fldName === 'ALL_FIELDS') {
                            propValue = JSON.parse(JSON.stringify(dataInfotable));
                            propValue.rows.push(lastData[selectedRowNo]);
                        } else {
                            propValue = lastData[selectedRowNo][thisWidget.getProperty(propName)];
                        if (propValue !== undefined) {
                            mashupSpec.mashupParameters[propName] = propValue;
                    $('#' + infoId).mashup(mashupSpec);
                }, 100);
                return;
    this.regionMouseOverEventListener = function (e) {
    if(this.rowNumber != lastRegionNumber) {
        regionInfoWindow.setContent(this.title);
            regionInfoWindow.open(this.map);
            regionInfoWindow.setPosition(this._tooltipCenter);
            lastRegionNumber = this.rowNumber;
    this.clickEventListener = function (e) {
                return;
    this.regionClickEventListener = function (e) {
        thisWidget.setSelectedRegion(this.rowNumber);
    this.dblclickEventListener = function (e) {
        thisWidget.jqElement.triggerHandler('DoubleClicked');
    this.cleanupRouteOverlays = function () {
        try {
            if (this.routePolyline !== undefined && this.routePolyline !== null) {
            google.maps.event.clearInstanceListeners(this.routePolyline);
                this.routePolyline.setMap(null);
                delete this.routePolyline;
        catch (destroyErr) {
//         alert('error in destroy routePolyline');
    this.cleanupPlannedRouteOverlays = function () {
        try {
            if (this.plannedRoutePolyline !== undefined && this.plannedRoutePolyline !== null) {
            google.maps.event.clearInstanceListeners(this.plannedRoutePolyline);
                this.plannedRoutePolyline.setMap(null);
                delete this.plannedRoutePolyline;
//         alert('error in destroy plannedRoutePolyline');
    this.cleanupRegionOverlays = function () {
        try {
            if (this.currentRegions !== undefined && this.currentRegions !== null) {
                for (var x = 0; x < this.currentRegions.length; x++) {
                    google.maps.event.clearListeners(this.currentRegions, 'click');
                    google.maps.event.clearListeners(this.currentRegions, 'mouseover');
                google.maps.event.clearInstanceListeners(this.currentRegions);
                this.currentRegions.setMap(null);
                this.currentRegions = null;
                this.currentRegions = {};
        catch (err) {
         TW.log.error('error cleanupRegionOverlays', err);
    this.cleanupMapOverlays = function () {
        try {
            if (this.polyline !== undefined && this.polyline !== null) {
            google.maps.event.clearInstanceListeners(this.polyline);
                this.polyline.setMap(null);
                delete this.polyline;
//         alert('error in destroy polyline');
        try {
            if (this.currentMarkers !== undefined) {
                for (var x = 0; x < this.currentMarkers.length; x++) {
                    if (isMashupTooltipConfigured) {
                        google.maps.event.clearListeners(this.currentMarkers, 'mouseover');
                    google.maps.event.clearListeners(this.currentMarkers, 'click');
                    google.maps.event.clearListeners(this.currentMarkers, 'dblclick');
                google.maps.event.clearInstanceListeners(this.currentMarkers);
                delete this.markerLookup.latlng;
                this.markerLookup.marker = null;
                delete this.markerLookup;
                this.currentMarkers.setMap(null);
                this.currentMarkers.rowNumber = null;
                this.currentMarkers.row = null;
                this.currentMarkers._isSelected = null;
                this.currentMarkers._assignedIcon = null;
                delete this.currentMarkers.rowNumber;
                delete this.currentMarkers.row;
                delete this.currentMarkers._isSelected;
                delete this.currentMarkers._assignedIcon;
                    delete this.currentMarkers;
                this.currentMarkers = [];
                this.markerLookup = [];
//         alert('error in destroy markers');
        try {
            if (this.startMarker !== null && this.startMarker !== undefined) {
                    google.maps.event.clearListeners(this.startMarker, 'mouseover');
                google.maps.event.clearListeners(this.startMarker, 'click');
                google.maps.event.clearListeners(this.startMarker, 'dblclick');
            google.maps.event.clearInstanceListeners(this.startMarker);
                this.startMarker.setMap(null);
                delete this.startMarker;
            if (this.endMarker !== null && this.endMarker !== undefined) {
                    google.maps.event.clearListeners(this.endMarker, 'mouseover');
                google.maps.event.clearListeners(this.endMarker, 'click');
                google.maps.event.clearListeners(this.endMarker, 'dblclick');
            google.maps.event.clearInstanceListeners(this.endMarker);
                this.endMarker.setMap(null);
                delete this.endMarker;
//         alert('error in destroy start/end');
        this.selectedRows = [];
    this.cleanupMapContent = function () {
    this.cleanupMapOverlays();
    this.cleanupRouteOverlays();
    this.cleanupPlannedRouteOverlays();
    this.cleanupRegionOverlays();
    try {
            if(this.trafficLayer !== null && this.trafficLayer !== undefined) {
            google.maps.event.clearInstanceListeners(this.trafficLayer);
                this.trafficLayer.setMap(null);
                this.trafficLayer = null;
                delete this.trafficLayer;
        try {
            if (this.selectionMarker !== null && this.selectionMarker !== undefined) {
            google.maps.event.clearInstanceListeners(this.selectionMarker);
                this.selectionMarker.setMap(null);
                delete this.selectionMarker;
    this.cleanupTooltipMashup = function () {
        try {
            var mashupTooltips = $('#' + infoId);
            if (mashupTooltips.length > 0) {
                mashupTooltips.mashup('destroy');
                TW.purgeJqElement(mashupTooltips);
    this.serviceInvoked = function (serviceName) {
        var widgetReference = this;
        if (serviceName === 'AutoZoom') {
                var effectiveBounds = new google.maps.LatLngBounds();
                if(widgetReference.routeDataBounds !== undefined) {
                effectiveBounds.union(widgetReference.routeDataBounds);
                if(widgetReference.plannedRouteDataBounds !== undefined) {
                effectiveBounds.union(widgetReference.plannedRouteDataBounds);
                if(widgetReference.regionDataBounds !== undefined) {
                effectiveBounds.union(widgetReference.regionDataBounds);
                if(widgetReference.dataBounds !== undefined) {
                effectiveBounds.union(widgetReference.dataBounds);
                widgetReference.map.fitBounds(effectiveBounds);
            }, 100);
        } else {
            TW.log.error('Google map widget, unexpected serviceName invoked "' + serviceName + '"');
    this.beforeDestroy = function () {
    this.cleanupMapContent();
    try {
       google.maps.event.clearInstanceListeners(this.map);
        catch(destroyErr) {
    this.cleanupTooltipMashup();
        //// put the map back in the body to be reused
    //$('body').append($('#global-map'));
    //$('#global-map').hide();
    dataInfotable = null;
    thisWidget = null;
    this.map = null;
    delete this.map;
    this.updateProperty = function (updatePropertyInfo) {
         var zoomOnDataRefresh = true;
                 if( userHasPannedOrZoomedSinceAutoZoom === true ) {
                 zoomOnDataRefresh = false;
         break;
         break;
         zoomOnDataRefresh = initialData;
         initialData = false;
         break;
         default:
            if (updatePropertyInfo.TargetProperty === 'Zoom') {
                var zoom = parseInt(updatePropertyInfo.RawSinglePropertyValue);
                this.map.setZoom(zoom);
                return;
            if (updatePropertyInfo.TargetProperty === 'ShowTraffic') {
                this.setProperty('ShowTraffic', updatePropertyInfo.RawSinglePropertyValue);
                if(this.trafficLayer === undefined || this.trafficLayer === null) {
                else{
                if(this.trafficLayer !== undefined) {
            if (updatePropertyInfo.TargetProperty === 'SelectedLocation') {
                var location = updatePropertyInfo.RawSinglePropertyValue;
                if (location != undefined && location.latitude != 0 && location.longitude != 0 && location.latitude != undefined && location.longitude != undefined) {
                    this.moveSelectionMarker(location);
                    this.map.setCenter(this.map.getCenter());
                } else {
                    thisWidget.setProperty('SelectedLocation', undefined);
                return;
            var redrawRoute = function() {
                var showRoute = this.getProperty('ShowRoute');
                if(showRoute) {
                    this.routeDataBounds = new google.maps.LatLngBounds();
                    var dataRows = updatePropertyInfo.ActualDataRows;
                    var locationField = this.getProperty('RouteLocationField');
                    var LatLngList = [];
                    var nRows = dataRows.length;
                    for (var rowNumber = 0; rowNumber < nRows; rowNumber++) {
                        var row = dataRows[rowNumber];
                        var thisLocation = row[locationField];
                        if (thisLocation !== undefined && thisLocation.latitude !== 0.0 && thisLocation.longitude !== 0.0) {
                            var latlng = new google.maps.LatLng(thisLocation.latitude, thisLocation.longitude);
                            LatLngList.push(latlng);
                            this.routeDataBounds.extend(latlng);
                    if (LatLngList.length > 1) {
                        this.routePolyline = new google.maps.Polyline({
                            path: LatLngList,
                            strokeColor: thisWidget.routeStyle.lineColor,
                            strokeOpacity: 1.0,
                            strokeWeight: parseInt(thisWidget.routeStyle.lineThickness)
                        this.routePolyline.setMap(thisWidget.map);
                    if(zoomOnDataRefresh ) {
                     // Autofit if we have more than one data point
                         if(this.routeDataBounds !== undefined) {
                          effectiveBounds.union(this.routeDataBounds);
                         if(this.regionDataBounds !== undefined) {
                          effectiveBounds.union(this.regionDataBounds);
                         if(this.dataBounds !== undefined) {
                          effectiveBounds.union(this.dataBounds);
                         this.map.fitBounds(effectiveBounds);
                     else {
                         if (LatLngList.length > 0) {
                             this.map.setCenter(LatLngList[0]);
                             this.map.setZoom(this.map.getZoom());
                return;
            if (updatePropertyInfo.TargetProperty === 'RouteData') {
                redrawRoute.call(this);
            var redrawPlannedRoute = function() {
                var showRoute = this.getProperty('ShowPlannedRoute');
                if(showRoute) {
                    this.plannedRouteDataBounds = new google.maps.LatLngBounds();
                    var locationField = this.getProperty('PlannedRouteLocationField');
                            this.plannedRouteDataBounds.extend(latlng);
                        this.plannedRoutePolyline = new google.maps.Polyline({
                            path: LatLngList,
                            strokeColor: thisWidget.plannedRouteStyle.lineColor,
                            strokeOpacity: 1.0,
                            strokeWeight: parseInt(thisWidget.plannedRouteStyle.lineThickness)
                        this.plannedRoutePolyline.setMap(thisWidget.map);
                         if(this.plannedRouteDataBounds !== undefined) {
                          effectiveBounds.union(this.plannedRouteDataBounds);
                     else {
                return;
            if (updatePropertyInfo.TargetProperty === 'PlannedRouteData') {
                redrawPlannedRoute.call(this);
            var redrawRegions = function() {
                var tooltipField1 = this.getProperty('RegionTooltipField1');
                var tooltipLabel1 = this.getProperty('RegionTooltipLabel1');
                var tooltipField2 = this.getProperty('RegionTooltipField2');
                var tooltipLabel2 = this.getProperty('RegionTooltipLabel2');
                var tooltipField3 = this.getProperty('RegionTooltipField3');
                var tooltipLabel3 = this.getProperty('RegionTooltipLabel3');
                var tooltipField4 = this.getProperty('RegionTooltipField4');
                var tooltipLabel4 = this.getProperty('RegionTooltipLabel4');
                var showRegions = this.getProperty('ShowRegions');
                var showRegionTooltips = this.getProperty('ShowRegionTooltips');
                if(showRegions) {
                    this.regionDataBounds = new google.maps.LatLngBounds();
                    var enableRegionSelection = this.getProperty('EnableRegionSelection');
                    var locationsField = this.getProperty('RegionLocationsField');
                    var locationField = this.getProperty('RegionLocationField');
                    var fillOpacity = this.getProperty('RegionFillOpacity');
                    this.currentRegions = [];
                        var locationTable = row[locationsField];
                        if(locationTable !== undefined) {
                            var RegionLatLngList = [];
                            var regionDataRows = locationTable.rows;
                            var nRegionRows = regionDataRows.length;
                            var polygonBounds = new google.maps.LatLngBounds();
                            for (var regionRowNumber = 0; regionRowNumber < nRegionRows; regionRowNumber++) {
                                var regionRow = regionDataRows[regionRowNumber];
                                var thisLocation = regionRow[locationField];
                                 RegionLatLngList.push(latlng);
                                 this.regionDataBounds.extend(latlng);
                                 polygonBounds.extend(latlng);
                            if (RegionLatLngList.length > 1) {
                                var hasRegionFormatting = thisWidget.properties['RegionFormatting'] !== undefined;
                                var formatStyle = thisWidget.regionStyle;
                                if (hasRegionFormatting) {
                                    formatStyle = TW.getStyleFromStateFormatting({ DataRow: row, StateFormatting: thisWidget.properties['RegionFormatting'] });
                                var regionProps = {
                                        paths: RegionLatLngList,
                                        strokeColor: formatStyle.lineColor,
                                        strokeOpacity: 1.0,
                                        strokeWeight: parseInt(formatStyle.lineThickness),
                                        fillColor: formatStyle.backgroundColor,
                                        fillOpacity: fillOpacity
                                var regionPolygon = new google.maps.Polygon(regionProps);
                                var regionLayerField = thisWidget.properties['RegionLayerField'];
                                if( regionPolygon['setZIndex'] !== undefined ) {
                                 if(regionLayerField !== undefined && regionLayerField !== '') {
                                     var regionLayer = row[regionLayerField];
                                     if(regionLayer !== undefined)
                                         regionPolygon.setZIndex(google.maps.Marker.MAX_ZINDEX + regionLayer);
                                     else
                                         regionPolygon.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
                                 else {
                                regionPolygon._assignedFillColor = formatStyle.backgroundColor;
                                regionPolygon._assignedStrokeColor = formatStyle.lineColor;
                                regionPolygon._assignedStrokeWeight = parseInt(formatStyle.lineThickness);
                                regionPolygon.rowNumber = rowNumber;
                                regionPolygon.rowData = row;
                                regionPolygon._isSelected = false;
                                regionPolygon._tooltipCenter = polygonBounds.getCenter();
                                regionPolygon.setMap(thisWidget.map);
                                if(enableRegionSelection) {
                                    google.maps.event.addListener(regionPolygon, 'click', this.regionClickEventListener);
                                this.currentRegions.push(regionPolygon);
                                if(showRegionTooltips) {
                                    var title = '';
                                    if (tooltipField1 !== undefined && tooltipField1 !== '') {
                                        if (tooltipLabel1 !== undefined && tooltipLabel1 !== '')
                                            title = title + tooltipLabel1 + ' : ';
                                        else
                                            title = title + tooltipField1 + ' : ';
                                        title = title + row[tooltipField1];
                                    if (tooltipField2 !== undefined && tooltipField2 !== '') {
                                        if (title.length > 0)
                                            title = title + '<BR>';
                                        if (tooltipLabel2 !== undefined && tooltipLabel2 !== '')
                                            title = title + tooltipLabel2 + ' : ';
                                        else
                                            title = title + tooltipField2 + ' : ';
                                        title = title + row[tooltipField2];
                                    if (tooltipField3 !== undefined && tooltipField3 !== '') {
                                        if (tooltipLabel3 !== undefined && tooltipLabel3 !== '')
                                            title = title + tooltipLabel3 + ' : ';
                                        else
                                            title = title + tooltipField3 + ' : ';
                                        title = title + row[tooltipField3];
                                    if (tooltipField4 !== undefined && tooltipField4 !== '') {
                                        if (tooltipLabel4 !== undefined && tooltipLabel4 !== '')
                                            title = title + tooltipLabel4 + ' : ';
                                        else
                                            title = title + tooltipField4 + ' : ';
                                        title = title + row[tooltipField4];
                                    if (title.length > 0) {
                                        regionPolygon.title = title;
                                        google.maps.event.addListener(regionPolygon, 'mouseover', this.regionMouseOverEventListener);
                    if(zoomOnDataRefresh) {
                     else {
                return;
            if (updatePropertyInfo.TargetProperty === 'RegionData') {
                redrawRegions.call(this);
            var redrawMap = function() {
                dataInfotable = {
                    dataShape: {
                        fieldDefinitions: updatePropertyInfo.DataShape
                    rows: []
                this.dataBounds = new google.maps.LatLngBounds();
                lastData = dataRows;
                var locationField = this.getProperty('LocationField');
                var tooltipField1 = this.getProperty('TooltipField1');
                var tooltipLabel1 = this.getProperty('TooltipLabel1');
                var tooltipField2 = this.getProperty('TooltipField2');
                var tooltipLabel2 = this.getProperty('TooltipLabel2');
                var tooltipField3 = this.getProperty('TooltipField3');
                var tooltipLabel3 = this.getProperty('TooltipLabel3');
                var tooltipField4 = this.getProperty('TooltipField4');
                var tooltipLabel4 = this.getProperty('TooltipLabel4');
                var showMarkers = this.getProperty('ShowMarkers');
                var showMarkerTooltips = this.getProperty('ShowMarkerTooltips');
                if(showMarkerTooltips == null || showMarkerTooltips == undefined)
                showMarkerTooltips = true;
                var enableMarkerSelection = this.getProperty('EnableMarkerSelection');
                        if (showMarkers) {
                            var markerProps = {
                                map: this.map,
                                position: latlng
                            if(showMarkerTooltips) {
                             var title = '';
                                 else
                                     title = title + '\n';
                                 else
                                 else
                                 else
                             if (title.length > 0 && !isMashupTooltipConfigured) {
                                 markerProps.title = title;
                            var markerField = thisWidget.properties['MarkerField'];
                            var hasFormatting = thisWidget.properties['MarkerFormatting'] !== undefined;
                            if (hasFormatting) {
                                var formatStyle = TW.getStyleFromStateFormatting({ DataRow: row, StateFormatting: thisWidget.properties['MarkerFormatting'] });
                                if (formatStyle.styleDefinitionName !== undefined) {
                                    markerProps.icon = formatStyle.image;
                                } else {
                                    markerProps.icon = thisWidget.markerStyle.image;
                            else
                            if(markerField !== undefined && markerField !== '') {
                            var markerImagePath = row[markerField];
                                if(markerImagePath !== undefined && markerImagePath !== '') {
                                markerProps.icon = markerImagePath;
                            var marker = new google.maps.Marker(markerProps);
                            marker.rowNumber = rowNumber;
                            marker.rowData = row;
                            marker._isSelected = false;
                            marker._assignedIcon = markerProps.icon;
                            var markerLayerField = thisWidget.properties['MarkerLayerField'];
                            if(markerLayerField !== undefined && markerLayerField !== '') {
                            var markerLayer = row[markerLayerField];
                            if(markerLayer !== undefined)
                            marker.setZIndex(google.maps.Marker.MAX_ZINDEX + markerLayer);
                            else
                            marker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
                            else
                            this.currentMarkers.push(marker);
                            this.markerLookup.push({ latlng : latlng, marker : marker});
                            // This funky code is because we are in a loop and need to do some closure magic
                                google.maps.event.addListener(marker, 'mouseover', this.mouseOverEventListener);
                            if (enableMarkerSelection) {
                                google.maps.event.addListener(marker, 'click', this.clickEventListener);
                                google.maps.event.addListener(marker, 'dblclick', this.dblclickEventListener);
                        this.dataBounds.extend(latlng);
                var showPathBetweenMarkers = this.getProperty('ShowPathBetweenMarkers');
                if (LatLngList.length > 1 && showPathBetweenMarkers) {
                    this.polyline = new google.maps.Polyline({
                        path: LatLngList,
                        strokeColor: thisWidget.pathStyle.lineColor,
                        strokeOpacity: 1.0,
                        strokeWeight: parseInt(thisWidget.pathStyle.lineThickness)
                    this.polyline.setMap(thisWidget.map);
                    if (this.getProperty('ShowEndMarker')) {
                        this.endMarker = new google.maps.Marker({
                            map: this.map,
                            position: LatLngList[LatLngList.length - 1],
                            title: "End",
                            icon: this.endMarkerStyle.image
                        this.endMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
                    if (this.getProperty('ShowStartMarker')) {
                        this.startMarker = new google.maps.Marker({
                            map: this.map,
                            position: LatLngList[0],
                            title: "Start",
                            icon: this.startMarkerStyle.image
                        this.startMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
                 else {
                // Finally, handle any pre-selected markers
                var selectedRowIndices = updatePropertyInfo.SelectedRowIndices;
                if (selectedRowIndices !== undefined) {
                    for (var selectedRowIndex = 0; selectedRowIndex < nSelectedRows; selectedRowIndex++) {
            if (updatePropertyInfo.TargetProperty === 'Data') {
                redrawMap.call(this);
            switch (updatePropertyInfo.TargetProperty) {
                case 'ShowPathBetweenMarkers':
                case 'ShowStartMarker':
                case 'ShowEndMarker':
                case 'ShowMarkers':
                    thisWidget.setProperty(updatePropertyInfo.TargetProperty, updatePropertyInfo.RawSinglePropertyValue);
                    break;
                case 'ShowRoute':
                    break;
                case 'ShowPlannedRoute':
                    break;
                case 'ShowRegions':
                    break;
aduarte
(To:done11)
I'm sorry, zoneColor it was for my case. You must replace it for the color that you want (format #000000).
