How to use google maps libraries like Drawing Library, Geometry Library and Places Library ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi all,
Does anyone know how to use google maps libraries like drawing library , geometry library and places library in google maps widget in thingworx ?
- Labels:
Mashup-Widget
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
There is a section of the Custom Extension Development Guide that talks about using custom widgets, and about using third party libraries in custom widgets.
Hope this helps!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
On the metadata.xml you can replace:
<FileResource description="" isRuntime="true" isDevelopment="false" type="JS" url="https://maps.google.com/maps/api/js?sensor=false"/>
By:
<FileResource type="JS" url="https://maps.google.com/maps/api/js?sensor=false&libraries=drawing,geometry"
description="" isDevelopment="false" isRuntime="true" />
I hope this can help you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Ana,
Thanks for your help.
I have updated the metadata.xml file as you said.
But how to use that in the map ? I am unable to use it .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I added another data source to save the shapes and i call the function that i use to add the drawing option at the updateProperty.
But I think that you can added the code that you need at the afterRender, after having the map:
this.map = new google.maps.Map(document.getElementById(this.jqElementId), options);
var polyOptions = {
strokeOpacity: 0.9,
strokeWeight: 2,
strokeColor: zoneColor,
fillOpacity: 0.50,
fillColor: zoneColor,
editable: true,
draggable: true
drawingManager = new google.maps.drawing.DrawingManager({
drawingControl: true,
drawingControlOptions: {
position: google.maps.ControlPosition.TOP_CENTER,
drawingModes: [
google.maps.drawing.OverlayType.CIRCLE,
google.maps.drawing.OverlayType.POLYGON
polygonOptions: polyOptions,
circleOptions: polyOptions
drawingManager.setMap(this.map);
drawingManager is declared as global variable.
For my case, i just want to give the option to draw polygons and circles.
This is only for drawing the shapes.
I hope this can help you,
drawingManager
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Ana,
I tried the above steps as you said but still I can't see the drawing options available at the top of the map.
Can you please help regarding this ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Of course, can you send me your code please?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
TW.Runtime.Widgets.googlemap = function () {
var infoWindow = undefined;
var drawingManager = undefined;
var userHasPannedOrZoomedSinceAutoZoom = false;
var initialData = true;
var weAreChangingBounds = false;
var autoZoomBehavior = 'every-data-change';
var regionInfoWindow = undefined;
var lastRegionNumber = undefined;
var lastData = undefined;
var lastRegionData = undefined;
var infoId = 'MapInfoWindow' + TW.uniqueId();
var tooltipMashupWidth = 100;
var tooltipMashupHeight = 100;
var isMashupTooltipConfigured = false;
var isRegionTooltipConfigured = false;
var dataInfotable = undefined;
this.runtimeProperties = function () {
return {
'supportsAutoResize': true,
'needsDataLoadingAndError': true,
'propertyAttributes': {
'TooltipLabel1': {'isLocalizable': true},
'TooltipLabel2': {'isLocalizable': true},
'TooltipLabel3': {'isLocalizable': true},
'TooltipLabel4': {'isLocalizable': true},
'RegionTooltipLabel1': {'isLocalizable': true},
'RegionTooltipLabel2': {'isLocalizable': true},
'RegionTooltipLabel3': {'isLocalizable': true},
'RegionTooltipLabel4': {'isLocalizable': true}
this.resize = function(width,height) {
try {
google.maps.event.trigger(this.map, 'resize');
} catch(err) {}
this.renderHtml = function () {
tooltipMashupWidth = thisWidget.getProperty('TooltipMashupWidth');
tooltipMashupHeight = thisWidget.getProperty('TooltipMashupHeight');
var oldAutoZoom = this.getProperty('AutoZoom');
autoZoomBehavior = this.getProperty('AutoZoomBehavior');
switch( autoZoomBehavior ) {
case 'disable-on-user-pan-zoom':
case 'only-when-autozoom-invoked':
case 'only-initial-data':
// leave these alone
break;
default:
// anything else, default to our old behavior
if( oldAutoZoom === undefined || oldAutoZoom === true ) {
} else if( oldAutoZoom === false ) {
autoZoomBehavior = 'only-when-autozoom-invoked';
} else {
break;
var mashupName = thisWidget.getProperty('TooltipMashupName');
if (mashupName !== undefined && mashupName.length > 0) {
isMashupTooltipConfigured = true;
try {
if (google !== undefined && google !== null) {
this.haveGoogleMaps = true;
catch (errmsg) {
if (this.haveGoogleMaps)
return '<div class="widget-content widget-map-runtime"></div>';
else
return '<div class="widget-content widget-map-runtime"><span class="textsize-large">Google Maps Are Not Available</span></div>';
var thisWidget = this;
this.haveGoogleMaps = false;
this.ignoreSelectionEvent = false;
this.ignoreRegionSelectionEvent = false;
this.map = undefined;
this.selectionMarker = null;
this.startMarker = null;
this.endMarker = null;
this.polyline = null;
this.routePolyline = null;
this.plannedRoutePolyline = null;
this.dataBounds;
this.plannedRouteDataBounds;
this.routeDataBounds;
this.regionDataBounds;
this.lastBounds;
this.lastZoom;
this.markerLookup = new Array();
this.currentMarkers = new Array();
this.selectedRows = new Array();
this.currentRegions = new Array();
this.selectedRegionRows = new Array();
this.markerStyle;
this.selectedMarkerStyle;
this.selectionMarkerStyle;
this.startMarkerStyle;
this.endMarkerStyle;
this.pathStyle;
this.routeStyle;
this.plannedRouteStyle;
this.regionStyle;
this.afterRender = function () {
this.markerStyle = TW.getStyleFromStyleDefinition(this.getProperty('MarkerStyle'));
this.selectionMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectionMarkerStyle'));
this.selectedMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectedMarkerStyle'));
this.startMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('StartMarkerStyle'));
this.endMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('EndMarkerStyle'));
this.pathStyle = TW.getStyleFromStyleDefinition(this.getProperty('PathStyle'));
this.plannedRouteStyle = TW.getStyleFromStyleDefinition(this.getProperty('PlannedRouteStyle'));
this.routeStyle = TW.getStyleFromStyleDefinition(this.getProperty('RouteStyle'));
this.regionStyle = TW.getStyleFromStyleDefinition(this.getProperty('RegionStyle'));
this.selectedRegionStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectedRegionStyle'));
if (this.haveGoogleMaps) {
var zoom = parseInt(this.getProperty('Zoom'));
var centerPosition = new google.maps.LatLng(TW.clientPosition.coords.latitude, TW.clientPosition.coords.longitude);
if (this.getProperty('SelectedLocation') !== undefined) {
centerPosition = new google.maps.LatLng(this.getProperty('SelectedLocation').latitude, this.getProperty('SelectedLocation').longitude);
var options = {
zoom: zoom,
center: centerPosition,
mapTypeId: this.getProperty('MapType')
switch( this.getProperty('MapSkin','normal') ) {
case 'normal':
break;
case 'blue':
options['styles'] = [{"featureType":"water","elementType":"geometry","stylers":[{"color":"#193341"}]},{"featureType":"landscape","elementType":"geometry","stylers":[{"color":"#2c5a71"}]},{"featureType":"road","elementType":"geometry","stylers":[{"color":"#29768a"},{"lightness":-37}]},{"featureType":"poi","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"featureType":"transit","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"elementType":"labels.text.stroke","stylers":[{"visibility":"on"},{"color":"#3e606f"},{"weight":2},{"gamma":0.84}]},{"elementType":"labels.text.fill","stylers":[{"color":"#ffffff"}]},{"featureType":"administrative","elementType":"geometry","stylers":[{"weight":0.6},{"color":"#1a3541"}]},{"elementType":"labels.icon","stylers":[{"visibility":"off"}]},{"featureType":"poi.park","elementType":"geometry","stylers":[{"color":"#2c5a71"}]}];
break;
case 'gray':
options['styles'] = [{"featureType":"landscape","stylers":[{"saturation":-100},{"lightness":65},{"visibility":"on"}]},{"featureType":"poi","stylers":[{"saturation":-100},{"lightness":51},{"visibility":"simplified"}]},{"featureType":"road.highway","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"road.arterial","stylers":[{"saturation":-100},{"lightness":30},{"visibility":"on"}]},{"featureType":"road.local","stylers":[{"saturation":-100},{"lightness":40},{"visibility":"on"}]},{"featureType":"transit","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"administrative.province","stylers":[{"visibility":"off"}]},{"featureType":"water","elementType":"labels","stylers":[{"visibility":"on"},{"lightness":-25},{"saturation":-100}]},{"featureType":"water","elementType":"geometry","stylers":[{"hue":"#ffff00"},{"lightness":-25},{"saturation":-97}]}];
break;
if (this.getProperty('EnableLocationSelection')) {
options["disableDoubleClickZoom"] = true;
else {
options["disableDoubleClickZoom"] = false;
//if (TW.Runtime.globalMap === undefined) {
// $('body').append(
// '<div id="global-map" style="top:0px;left:0px;width:200px;height:200px;">' +
// '</div>');
// TW.Runtime.globalMap = new google.maps.Map(document.getElementById('global-map'), options);
//this.map = TW.Runtime.globalMap;
//this.jqElement.append($('#global-map'));
//$('#global-map').show().css('height', this.getProperty('Height') + 'px').css('width', this.getProperty('Width') + 'px');
var polyOptions = {
strokeOpacity: 0.9,
strokeWeight: 2,
fillOpacity: 0.50,
editable: true,
draggable: true
drawingModes: [
infoWindow = new google.maps.InfoWindow();
regionInfoWindow = new google.maps.InfoWindow();
if(this.getProperty('ShowTraffic')) {
this.trafficLayer = new google.maps.TrafficLayer();
this.trafficLayer.setMap(this.map);
google.maps.event.addListener(this.map, 'idle', function (event) {
var bounds = thisWidget.map.getBounds();
var changed = false;
if(thisWidget.lastBounds !== undefined) {
if(thisWidget.lastBounds.getNorthEast().lat() != bounds.getNorthEast().lat())
changed = true;
if(thisWidget.lastBounds.getNorthEast().lng() != bounds.getNorthEast().lng())
changed = true;
if(thisWidget.lastBounds.getSouthWest().lat() != bounds.getSouthWest().lat())
changed = true;
if(thisWidget.lastBounds.getSouthWest().lng() != bounds.getSouthWest().lng())
changed = true;
else {
changed = true;
if(changed) {
// ignore this if it's just getting the initial bearings
if( thisWidget.lastBounds !== undefined ) {
if( !weAreChangingBounds ) {
userHasPannedOrZoomedSinceAutoZoom = true;
var nelocation = new Object();
nelocation.units = "WGS84";
nelocation.elevation = 0.0;
nelocation.latitude = bounds.getNorthEast().lat();
nelocation.longitude = bounds.getNorthEast().lng();
thisWidget.setProperty('NEBoundary', nelocation);
var swlocation = new Object();
swlocation.units = "WGS84";
swlocation.elevation = 0.0;
swlocation.latitude = bounds.getSouthWest().lat();
swlocation.longitude = bounds.getSouthWest().lng();
thisWidget.setProperty('SWBoundary', swlocation);
nelocation.latitude = bounds.getSouthWest().lat();
thisWidget.setProperty('SEBoundary', nelocation);
swlocation.latitude = bounds.getNorthEast().lat();
thisWidget.setProperty('NWBoundary', swlocation);
thisWidget.lastBounds = bounds;
thisWidget.jqElement.triggerHandler('BoundsChanged');
var zoomChanged = false;
var currentZoom = thisWidget.map.getZoom();
if(thisWidget.lastZoom !== undefined) {
if(thisWidget.lastZoom != currentZoom)
zooomChanged = true;
else {
zoomChanged = true;
if(zoomChanged) {
thisWidget.setProperty('CurrentZoom', currentZoom);
thisWidget.lastZoom = currentZoom;
if (this.getProperty('ShowSelectionMarker') === true) {
this.selectionMarker = new google.maps.Marker({
map: this.map,
position: centerPosition,
title: "Selection",
icon: this.selectionMarkerStyle.image
this.selectionMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 3);
google.maps.event.addListener(this.map, 'dblclick', function (event) {
var location = new Object();
location.latitude = event.latLng.lat();
location.longitude = event.latLng.lng();
thisWidget.moveSelectionMarker(location);
thisWidget.setProperty('SelectedLocation', location);
thisWidget.jqElement.triggerHandler('Changed');
weAreChangingBounds = true;
this.map.setZoom(this.map.getZoom() - 1);
this.map.setZoom(this.map.getZoom() + 1);
this.moveSelectionMarker = function (newLocation) {
if (newLocation !== undefined) {
var latlng = new google.maps.LatLng(newLocation.latitude, newLocation.longitude);
if (this.selectionMarker !== null) {
this.selectionMarker.setMap(this.map);
this.selectionMarker.setPosition(latlng);
} else {
position: latlng,
map: this.map,
title: "Selection",
this.map.setCenter(latlng);
this.clearSelectedRegions = function () {
thisWidget.selectedRegionRows = [];
for (var regionNo = 0; regionNo < thisWidget.currentRegions.length; regionNo++) {
var currentRegion = thisWidget.currentRegions[regionNo];
currentRegion.setOptions( { fillColor: currentRegion._assignedFillColor, strokeColor : currentRegion._assignedStrokeColor, strokeWeight : currentRegion._assignedStrokeWeight });
currentRegion._isSelected = false;
this.clearSelectedMarkers = function () {
thisWidget.selectedRows = [];
for (var markerNo = 0; markerNo < thisWidget.currentMarkers.length; markerNo++) {
var currentMarker = thisWidget.currentMarkers[markerNo];
currentMarker._isSelected = false;
currentMarker.setIcon(currentMarker._assignedIcon);
currentMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
this.setSelectedMarker = function (selectedRow) {
var isMultiselect = thisWidget.properties['MultiSelect'];
var selectedMarker;
if (currentMarker.rowNumber === selectedRow) {
selectedMarker = currentMarker;
break;
if (selectedMarker !== undefined) {
if (selectedMarker._isSelected) {
if (isMultiselect) {
TW.removeElementFromArray(thisWidget.selectedRows, selectedRow);
selectedMarker._isSelected = false;
selectedMarker.setIcon(selectedMarker._assignedIcon);
selectedMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
if (!thisWidget.ignoreSelectionEvent) {
thisWidget.updateSelection('Data', thisWidget.selectedRows);
else {
if (!isMultiselect) {
thisWidget.clearSelectedMarkers();
thisWidget.selectedRows = [selectedRow];
else
thisWidget.selectedRows.push(selectedRow);
selectedMarker.setIcon(thisWidget.selectedMarkerStyle.image);
selectedMarker._isSelected = true;
selectedMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
this.setSelectedRegion = function (selectedRow) {
var isMultiselect = thisWidget.properties['RegionMultiSelect'];
var selectedRegion;
if (currentRegion.rowNumber === selectedRow) {
selectedRegion = currentRegion;
break;
if (selectedRegion !== undefined) {
if (selectedRegion._isSelected) {
TW.removeElementFromArray(thisWidget.selectedRegionRows, selectedRow);
selectedRegion._isSelected = false;
selectedRegion.setOptions( { fillColor: selectedRegion._assignedFillColor, strokeColor : selectedRegion._assignedStrokeColor, strokeWeight : selectedRegion._assignedStrokeWeight });
if (!thisWidget.ignoreRegionSelectionEvent) {
thisWidget.updateSelection('RegionData', thisWidget.selectedRegionRows);
else {
thisWidget.clearSelectedRegions();
thisWidget.selectedRegionRows = [selectedRow];
else
thisWidget.selectedRegionRows.push(selectedRow);
selectedRegion._isSelected = true;
selectedRegion.setOptions( { fillColor: thisWidget.selectedRegionStyle.backgroundColor, strokeColor : thisWidget.selectedRegionStyle.lineColor, strokeWeight : parseInt(thisWidget.selectedRegionStyle.lineThickness) });
this.handleSelectionUpdate = function (propertyName, selectedRows, selectedRowIndices) {
if (propertyName == "Data") {
thisWidget.ignoreSelectionEvent = true;
var nSelectedRows = selectedRowIndices.length;
for (var selectedRowIndex = 0; selectedRowIndex < nSelectedRows;selectedRowIndex++) {
thisWidget.setSelectedMarker(selectedRowIndices[selectedRowIndex]);
thisWidget.ignoreSelectionEvent = false;
if (propertyName == "RegionData") {
thisWidget.ignoreRegionSelectionEvent = true;
thisWidget.setSelectedRegion(selectedRowIndices[selectedRowIndex]);
thisWidget.ignoreRegionSelectionEvent = false;
this.mouseOverEventListener = function (e) {
var latlng = e.latLng;
if (!isMashupTooltipConfigured) {
return;
var markerCount = thisWidget.markerLookup.length;
for (var i = 0; i < markerCount; i++) {
var markerInfo = thisWidget.markerLookup;
if (latlng.lat() == markerInfo.latlng.lat() && latlng.lng() == markerInfo.latlng.lng()) {
var selectedMarker = markerInfo.marker;
var selectedRowNo = selectedMarker.rowNumber;
TW.log.info('Should display info for Row #' + selectedRowNo);
//thisWidget.setSelectedMarker(selectedRowNo);
thisWidget.cleanupTooltipMashup();
infoWindow.setContent('<div id="' + infoId + '" style="width:' + tooltipMashupWidth + 'px;height:' + tooltipMashupHeight + 'px;">Loading Tooltip Mashup...</div>');
//infoWindow.setContent('<div id="' + infoId + '" style="">Hello there, selected Row #' + selectedRowNo + ', "' + lastData[selectedRowNo]['name'] + '"</div>');
//infoWindow.setContent('Hello there, selected Row #' + selectedRowNo + '');
infoWindow.setPosition(markerInfo.latlng);
infoWindow.open(this.map, markerInfo.marker);
setTimeout(function () {
var mashupSpec = {};
mashupSpec.mashupName = thisWidget.getProperty('TooltipMashupName');
mashupSpec.mashupParameters = {};
var mashupParameters = thisWidget.properties['MashupParameters'];
if (mashupParameters === undefined)
mashupParameters = [];
var nParams = mashupParameters.length;
for (var paramNo = 0; paramNo < nParams; paramNo++) {
var paramInfo = mashupParameters[paramNo],
propName = paramInfo.ParameterName,
fldName = thisWidget.getProperty(propName),
propValue;
if (fldName === 'ALL_FIELDS') {
propValue = JSON.parse(JSON.stringify(dataInfotable));
propValue.rows.push(lastData[selectedRowNo]);
} else {
propValue = lastData[selectedRowNo][thisWidget.getProperty(propName)];
if (propValue !== undefined) {
mashupSpec.mashupParameters[propName] = propValue;
$('#' + infoId).mashup(mashupSpec);
}, 100);
return;
this.regionMouseOverEventListener = function (e) {
if(this.rowNumber != lastRegionNumber) {
regionInfoWindow.setContent(this.title);
regionInfoWindow.open(this.map);
regionInfoWindow.setPosition(this._tooltipCenter);
lastRegionNumber = this.rowNumber;
this.clickEventListener = function (e) {
return;
this.regionClickEventListener = function (e) {
thisWidget.setSelectedRegion(this.rowNumber);
this.dblclickEventListener = function (e) {
thisWidget.jqElement.triggerHandler('DoubleClicked');
this.cleanupRouteOverlays = function () {
try {
if (this.routePolyline !== undefined && this.routePolyline !== null) {
google.maps.event.clearInstanceListeners(this.routePolyline);
this.routePolyline.setMap(null);
delete this.routePolyline;
catch (destroyErr) {
// alert('error in destroy routePolyline');
this.cleanupPlannedRouteOverlays = function () {
try {
if (this.plannedRoutePolyline !== undefined && this.plannedRoutePolyline !== null) {
google.maps.event.clearInstanceListeners(this.plannedRoutePolyline);
this.plannedRoutePolyline.setMap(null);
delete this.plannedRoutePolyline;
// alert('error in destroy plannedRoutePolyline');
this.cleanupRegionOverlays = function () {
try {
if (this.currentRegions !== undefined && this.currentRegions !== null) {
for (var x = 0; x < this.currentRegions.length; x++) {
google.maps.event.clearListeners(this.currentRegions
google.maps.event.clearInstanceListeners(this.currentRegions
this.currentRegions
this.currentRegions
this.currentRegions = {};
catch (err) {
TW.log.error('error cleanupRegionOverlays', err);
this.cleanupMapOverlays = function () {
try {
if (this.polyline !== undefined && this.polyline !== null) {
google.maps.event.clearInstanceListeners(this.polyline);
this.polyline.setMap(null);
delete this.polyline;
// alert('error in destroy polyline');
try {
if (this.currentMarkers !== undefined) {
for (var x = 0; x < this.currentMarkers.length; x++) {
if (isMashupTooltipConfigured) {
google.maps.event.clearListeners(this.currentMarkers
google.maps.event.clearInstanceListeners(this.currentMarkers
delete this.markerLookup
this.markerLookup
this.currentMarkers
this.currentMarkers
this.currentMarkers
this.currentMarkers
this.currentMarkers
delete this.currentMarkers
this.currentMarkers = [];
this.markerLookup = [];
// alert('error in destroy markers');
try {
if (this.startMarker !== null && this.startMarker !== undefined) {
google.maps.event.clearListeners(this.startMarker, 'mouseover');
google.maps.event.clearListeners(this.startMarker, 'click');
google.maps.event.clearListeners(this.startMarker, 'dblclick');
google.maps.event.clearInstanceListeners(this.startMarker);
this.startMarker.setMap(null);
delete this.startMarker;
if (this.endMarker !== null && this.endMarker !== undefined) {
google.maps.event.clearListeners(this.endMarker, 'mouseover');
google.maps.event.clearListeners(this.endMarker, 'click');
google.maps.event.clearListeners(this.endMarker, 'dblclick');
google.maps.event.clearInstanceListeners(this.endMarker);
this.endMarker.setMap(null);
delete this.endMarker;
// alert('error in destroy start/end');
this.selectedRows = [];
this.cleanupMapContent = function () {
this.cleanupMapOverlays();
this.cleanupRouteOverlays();
this.cleanupPlannedRouteOverlays();
this.cleanupRegionOverlays();
try {
if(this.trafficLayer !== null && this.trafficLayer !== undefined) {
google.maps.event.clearInstanceListeners(this.trafficLayer);
this.trafficLayer.setMap(null);
this.trafficLayer = null;
delete this.trafficLayer;
try {
if (this.selectionMarker !== null && this.selectionMarker !== undefined) {
google.maps.event.clearInstanceListeners(this.selectionMarker);
this.selectionMarker.setMap(null);
delete this.selectionMarker;
this.cleanupTooltipMashup = function () {
try {
var mashupTooltips = $('#' + infoId);
if (mashupTooltips.length > 0) {
mashupTooltips.mashup('destroy');
TW.purgeJqElement(mashupTooltips);
this.serviceInvoked = function (serviceName) {
var widgetReference = this;
if (serviceName === 'AutoZoom') {
var effectiveBounds = new google.maps.LatLngBounds();
if(widgetReference.routeDataBounds !== undefined) {
effectiveBounds.union(widgetReference.routeDataBounds);
if(widgetReference.plannedRouteDataBounds !== undefined) {
effectiveBounds.union(widgetReference.plannedRouteDataBounds);
if(widgetReference.regionDataBounds !== undefined) {
effectiveBounds.union(widgetReference.regionDataBounds);
if(widgetReference.dataBounds !== undefined) {
effectiveBounds.union(widgetReference.dataBounds);
widgetReference.map.fitBounds(effectiveBounds);
}, 100);
} else {
TW.log.error('Google map widget, unexpected serviceName invoked "' + serviceName + '"');
this.beforeDestroy = function () {
this.cleanupMapContent();
try {
google.maps.event.clearInstanceListeners(this.map);
catch(destroyErr) {
this.cleanupTooltipMashup();
//// put the map back in the body to be reused
//$('body').append($('#global-map'));
//$('#global-map').hide();
dataInfotable = null;
thisWidget = null;
this.map = null;
delete this.map;
this.updateProperty = function (updatePropertyInfo) {
var zoomOnDataRefresh = true;
if( userHasPannedOrZoomedSinceAutoZoom === true ) {
zoomOnDataRefresh = false;
break;
break;
zoomOnDataRefresh = initialData;
initialData = false;
break;
default:
if (updatePropertyInfo.TargetProperty === 'Zoom') {
var zoom = parseInt(updatePropertyInfo.RawSinglePropertyValue);
this.map.setZoom(zoom);
return;
if (updatePropertyInfo.TargetProperty === 'ShowTraffic') {
this.setProperty('ShowTraffic', updatePropertyInfo.RawSinglePropertyValue);
if(this.trafficLayer === undefined || this.trafficLayer === null) {
else{
if(this.trafficLayer !== undefined) {
if (updatePropertyInfo.TargetProperty === 'SelectedLocation') {
var location = updatePropertyInfo.RawSinglePropertyValue;
if (location != undefined && location.latitude != 0 && location.longitude != 0 && location.latitude != undefined && location.longitude != undefined) {
this.moveSelectionMarker(location);
this.map.setCenter(this.map.getCenter());
} else {
thisWidget.setProperty('SelectedLocation', undefined);
return;
var redrawRoute = function() {
var showRoute = this.getProperty('ShowRoute');
if(showRoute) {
this.routeDataBounds = new google.maps.LatLngBounds();
var dataRows = updatePropertyInfo.ActualDataRows;
var locationField = this.getProperty('RouteLocationField');
var LatLngList = [];
var nRows = dataRows.length;
for (var rowNumber = 0; rowNumber < nRows; rowNumber++) {
var row = dataRows[rowNumber];
var thisLocation = row[locationField];
if (thisLocation !== undefined && thisLocation.latitude !== 0.0 && thisLocation.longitude !== 0.0) {
var latlng = new google.maps.LatLng(thisLocation.latitude, thisLocation.longitude);
LatLngList.push(latlng);
this.routeDataBounds.extend(latlng);
if (LatLngList.length > 1) {
this.routePolyline = new google.maps.Polyline({
path: LatLngList,
strokeColor: thisWidget.routeStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(thisWidget.routeStyle.lineThickness)
this.routePolyline.setMap(thisWidget.map);
if(zoomOnDataRefresh ) {
// Autofit if we have more than one data point
if(this.routeDataBounds !== undefined) {
effectiveBounds.union(this.routeDataBounds);
if(this.regionDataBounds !== undefined) {
effectiveBounds.union(this.regionDataBounds);
if(this.dataBounds !== undefined) {
effectiveBounds.union(this.dataBounds);
this.map.fitBounds(effectiveBounds);
else {
if (LatLngList.length > 0) {
this.map.setCenter(LatLngList[0]);
this.map.setZoom(this.map.getZoom());
return;
if (updatePropertyInfo.TargetProperty === 'RouteData') {
redrawRoute.call(this);
var redrawPlannedRoute = function() {
var showRoute = this.getProperty('ShowPlannedRoute');
if(showRoute) {
this.plannedRouteDataBounds = new google.maps.LatLngBounds();
var locationField = this.getProperty('PlannedRouteLocationField');
this.plannedRouteDataBounds.extend(latlng);
this.plannedRoutePolyline = new google.maps.Polyline({
path: LatLngList,
strokeColor: thisWidget.plannedRouteStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(thisWidget.plannedRouteStyle.lineThickness)
this.plannedRoutePolyline.setMap(thisWidget.map);
if(this.plannedRouteDataBounds !== undefined) {
effectiveBounds.union(this.plannedRouteDataBounds);
else {
return;
if (updatePropertyInfo.TargetProperty === 'PlannedRouteData') {
redrawPlannedRoute.call(this);
var redrawRegions = function() {
var tooltipField1 = this.getProperty('RegionTooltipField1');
var tooltipLabel1 = this.getProperty('RegionTooltipLabel1');
var tooltipField2 = this.getProperty('RegionTooltipField2');
var tooltipLabel2 = this.getProperty('RegionTooltipLabel2');
var tooltipField3 = this.getProperty('RegionTooltipField3');
var tooltipLabel3 = this.getProperty('RegionTooltipLabel3');
var tooltipField4 = this.getProperty('RegionTooltipField4');
var tooltipLabel4 = this.getProperty('RegionTooltipLabel4');
var showRegions = this.getProperty('ShowRegions');
var showRegionTooltips = this.getProperty('ShowRegionTooltips');
if(showRegions) {
this.regionDataBounds = new google.maps.LatLngBounds();
var enableRegionSelection = this.getProperty('EnableRegionSelection');
var locationsField = this.getProperty('RegionLocationsField');
var locationField = this.getProperty('RegionLocationField');
var fillOpacity = this.getProperty('RegionFillOpacity');
this.currentRegions = [];
var locationTable = row[locationsField];
if(locationTable !== undefined) {
var RegionLatLngList = [];
var regionDataRows = locationTable.rows;
var nRegionRows = regionDataRows.length;
var polygonBounds = new google.maps.LatLngBounds();
for (var regionRowNumber = 0; regionRowNumber < nRegionRows; regionRowNumber++) {
var regionRow = regionDataRows[regionRowNumber];
var thisLocation = regionRow[locationField];
RegionLatLngList.push(latlng);
this.regionDataBounds.extend(latlng);
polygonBounds.extend(latlng);
if (RegionLatLngList.length > 1) {
var hasRegionFormatting = thisWidget.properties['RegionFormatting'] !== undefined;
var formatStyle = thisWidget.regionStyle;
if (hasRegionFormatting) {
formatStyle = TW.getStyleFromStateFormatting({ DataRow: row, StateFormatting: thisWidget.properties['RegionFormatting'] });
var regionProps = {
paths: RegionLatLngList,
strokeColor: formatStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(formatStyle.lineThickness),
fillColor: formatStyle.backgroundColor,
fillOpacity: fillOpacity
var regionPolygon = new google.maps.Polygon(regionProps);
var regionLayerField = thisWidget.properties['RegionLayerField'];
if( regionPolygon['setZIndex'] !== undefined ) {
if(regionLayerField !== undefined && regionLayerField !== '') {
var regionLayer = row[regionLayerField];
if(regionLayer !== undefined)
regionPolygon.setZIndex(google.maps.Marker.MAX_ZINDEX + regionLayer);
else
regionPolygon.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
else {
regionPolygon._assignedFillColor = formatStyle.backgroundColor;
regionPolygon._assignedStrokeColor = formatStyle.lineColor;
regionPolygon._assignedStrokeWeight = parseInt(formatStyle.lineThickness);
regionPolygon.rowNumber = rowNumber;
regionPolygon.rowData = row;
regionPolygon._isSelected = false;
regionPolygon._tooltipCenter = polygonBounds.getCenter();
regionPolygon.setMap(thisWidget.map);
if(enableRegionSelection) {
google.maps.event.addListener(regionPolygon, 'click', this.regionClickEventListener);
this.currentRegions.push(regionPolygon);
if(showRegionTooltips) {
var title = '';
if (tooltipField1 !== undefined && tooltipField1 !== '') {
if (tooltipLabel1 !== undefined && tooltipLabel1 !== '')
title = title + tooltipLabel1 + ' : ';
else
title = title + tooltipField1 + ' : ';
title = title + row[tooltipField1];
if (tooltipField2 !== undefined && tooltipField2 !== '') {
if (title.length > 0)
title = title + '<BR>';
if (tooltipLabel2 !== undefined && tooltipLabel2 !== '')
title = title + tooltipLabel2 + ' : ';
else
title = title + tooltipField2 + ' : ';
title = title + row[tooltipField2];
if (tooltipField3 !== undefined && tooltipField3 !== '') {
if (tooltipLabel3 !== undefined && tooltipLabel3 !== '')
title = title + tooltipLabel3 + ' : ';
else
title = title + tooltipField3 + ' : ';
title = title + row[tooltipField3];
if (tooltipField4 !== undefined && tooltipField4 !== '') {
if (tooltipLabel4 !== undefined && tooltipLabel4 !== '')
title = title + tooltipLabel4 + ' : ';
else
title = title + tooltipField4 + ' : ';
title = title + row[tooltipField4];
if (title.length > 0) {
regionPolygon.title = title;
google.maps.event.addListener(regionPolygon, 'mouseover', this.regionMouseOverEventListener);
if(zoomOnDataRefresh) {
else {
return;
if (updatePropertyInfo.TargetProperty === 'RegionData') {
redrawRegions.call(this);
var redrawMap = function() {
dataInfotable = {
dataShape: {
fieldDefinitions: updatePropertyInfo.DataShape
rows: []
this.dataBounds = new google.maps.LatLngBounds();
lastData = dataRows;
var locationField = this.getProperty('LocationField');
var tooltipField1 = this.getProperty('TooltipField1');
var tooltipLabel1 = this.getProperty('TooltipLabel1');
var tooltipField2 = this.getProperty('TooltipField2');
var tooltipLabel2 = this.getProperty('TooltipLabel2');
var tooltipField3 = this.getProperty('TooltipField3');
var tooltipLabel3 = this.getProperty('TooltipLabel3');
var tooltipField4 = this.getProperty('TooltipField4');
var tooltipLabel4 = this.getProperty('TooltipLabel4');
var showMarkers = this.getProperty('ShowMarkers');
var showMarkerTooltips = this.getProperty('ShowMarkerTooltips');
if(showMarkerTooltips == null || showMarkerTooltips == undefined)
showMarkerTooltips = true;
var enableMarkerSelection = this.getProperty('EnableMarkerSelection');
if (showMarkers) {
var markerProps = {
map: this.map,
position: latlng
if(showMarkerTooltips) {
var title = '';
else
title = title + '\n';
else
else
else
if (title.length > 0 && !isMashupTooltipConfigured) {
markerProps.title = title;
var markerField = thisWidget.properties['MarkerField'];
var hasFormatting = thisWidget.properties['MarkerFormatting'] !== undefined;
if (hasFormatting) {
var formatStyle = TW.getStyleFromStateFormatting({ DataRow: row, StateFormatting: thisWidget.properties['MarkerFormatting'] });
if (formatStyle.styleDefinitionName !== undefined) {
markerProps.icon = formatStyle.image;
} else {
markerProps.icon = thisWidget.markerStyle.image;
else
if(markerField !== undefined && markerField !== '') {
var markerImagePath = row[markerField];
if(markerImagePath !== undefined && markerImagePath !== '') {
markerProps.icon = markerImagePath;
var marker = new google.maps.Marker(markerProps);
marker.rowNumber = rowNumber;
marker.rowData = row;
marker._isSelected = false;
marker._assignedIcon = markerProps.icon;
var markerLayerField = thisWidget.properties['MarkerLayerField'];
if(markerLayerField !== undefined && markerLayerField !== '') {
var markerLayer = row[markerLayerField];
if(markerLayer !== undefined)
marker.setZIndex(google.maps.Marker.MAX_ZINDEX + markerLayer);
else
marker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
else
this.currentMarkers.push(marker);
this.markerLookup.push({ latlng : latlng, marker : marker});
// This funky code is because we are in a loop and need to do some closure magic
google.maps.event.addListener(marker, 'mouseover', this.mouseOverEventListener);
if (enableMarkerSelection) {
google.maps.event.addListener(marker, 'click', this.clickEventListener);
google.maps.event.addListener(marker, 'dblclick', this.dblclickEventListener);
this.dataBounds.extend(latlng);
var showPathBetweenMarkers = this.getProperty('ShowPathBetweenMarkers');
if (LatLngList.length > 1 && showPathBetweenMarkers) {
this.polyline = new google.maps.Polyline({
path: LatLngList,
strokeColor: thisWidget.pathStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(thisWidget.pathStyle.lineThickness)
this.polyline.setMap(thisWidget.map);
if (this.getProperty('ShowEndMarker')) {
this.endMarker = new google.maps.Marker({
map: this.map,
position: LatLngList[LatLngList.length - 1],
title: "End",
icon: this.endMarkerStyle.image
this.endMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
if (this.getProperty('ShowStartMarker')) {
this.startMarker = new google.maps.Marker({
map: this.map,
position: LatLngList[0],
title: "Start",
icon: this.startMarkerStyle.image
this.startMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
else {
// Finally, handle any pre-selected markers
var selectedRowIndices = updatePropertyInfo.SelectedRowIndices;
if (selectedRowIndices !== undefined) {
for (var selectedRowIndex = 0; selectedRowIndex < nSelectedRows; selectedRowIndex++) {
if (updatePropertyInfo.TargetProperty === 'Data') {
redrawMap.call(this);
switch (updatePropertyInfo.TargetProperty) {
case 'ShowPathBetweenMarkers':
case 'ShowStartMarker':
case 'ShowEndMarker':
case 'ShowMarkers':
thisWidget.setProperty(updatePropertyInfo.TargetProperty, updatePropertyInfo.RawSinglePropertyValue);
break;
case 'ShowRoute':
break;
case 'ShowPlannedRoute':
break;
case 'ShowRegions':
break;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I'm sorry, zoneColor it was for my case. You must replace it for the color that you want (format #000000).
