Dec 9, 2016 1:34 PM UTC
How to use google maps libraries like Drawing Library, Geometry Library and Places Library ?
Hi all,
Does anyone know how to use google maps libraries like drawing library , geometry library and places library in google maps widget in thingworx ?
Dec 9, 2016 11:53 PM UTC
There is a section of the Custom Extension Development Guide that talks about using custom widgets, and about using third party libraries in custom widgets.
Hope this helps!
Dec 26, 2016 12:27 PM UTC
On the metadata.xml you can replace:
<FileResource description="" isRuntime="true" isDevelopment="false" type="JS" url="https://maps.google.com/maps/api/js?sensor=false"/>
By:
<FileResource type="JS" url="https://maps.google.com/maps/api/js?sensor=false&amp;libraries=drawing,geometry"
  description="" isDevelopment="false" isRuntime="true" />
I hope this can help you.
done111-VisitorAuthor
Jan 12, 2017 10:56 AM UTC
Hi Ana,
Thanks for your help.
I have updated the metadata.xml file as you said.
But how to use that in the map ? I am unable to use it .
Jan 16, 2017 9:41 AM UTC
I added another data source to save the shapes and i call the function that i use to add the drawing option at the updateProperty.
But I think that you can added the code that you need at the afterRender, after having the map:
      this.map = new google.maps.Map(document.getElementById(this.jqElementId), options);
var polyOptions = {
  strokeOpacity: 0.9,
  strokeWeight: 2,
  strokeColor: zoneColor,
  fillOpacity: 0.50,
  fillColor: zoneColor,
  editable: true,
  draggable: true
drawingManager = new google.maps.drawing.DrawingManager({
  drawingControl: true,
  drawingControlOptions: {
   position: google.maps.ControlPosition.TOP_CENTER,
   drawingModes: [
         google.maps.drawing.OverlayType.CIRCLE,
         google.maps.drawing.OverlayType.POLYGON
  polygonOptions: polyOptions,
  circleOptions: polyOptions
drawingManager.setMap(this.map);
drawingManager is declared as global variable.
For my case, i just want to give the option to draw polygons and circles.
This is only for drawing the shapes.
I hope this can help you,
drawingManager
