Hello, I need to find a non-destructive way of writing into a class aspects constant ASPECT_DATACHANGETHRESHOLD at ThingShape level. I'd be grateful for your help!
You can set the aspect dataChangeThreshold directly in ThingWorx Composer when defining the property on the ThingShape under "Data Change Info > Change Threshold". Are you looking for a means to set this aspect that does not involve the ThingWorx Composer?
correct
I'd like to have more context on your particular use case. Can you elaborate? Do you have an existing ThingShape and want to set the dataChangeThreshold aspect programmatically? Or are you programmatically creating a ThingShape and need to set the aspect of the dataChangeThreshold of the properties you are adding?
Thank you for the context.
After some investigation, I do not believe there is any way for you to accomplish what you are trying programmatically. I do believe that what you are trying to do should be available programmatically. Therefore, I would suggest you submit a support ticket for your use case. I will also respond to the other thread.
You can set aspects in your java extension, ThingWorx Eclipse plugin makes it especially easy.
