I want to show status of program starting before 2 hrs and 15 min before if program is start then I want to show status is ON and after finish program it show me Your program is expired
I have two use case for assign status for program as below
1) I want to assign program/Batches for every day
2) Assign program weekly once or twice programs
please refer below attachment for better understand and suggest how to write service for assign status for program??
Thanks in advance
Thanks for your reply, Can you please suggest in detail How do I used scheduler/timer for calculating status and how to bind ? or Is their possible through service if it Yes then how to write service for assign status for program??
Hello @RM12
Please refer following article for your reference:
https://www.ptc.com/en/support/article/CS328097
Hope it will answer your query.
Om Dukiya
Hi @RM12.
If one of the previous responses answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
