Hi All,
I had create my project in a older Thingworx version, it works fine.
I can create the query.
when i migrate to a New version 8.4.2 ? I am not able to create a query.
the arrow seem different??
Can anyone guide me? Not sure if there is a change in step to create query?
Please do direct me to any tutorial or document which show how to do it. I will try it out.
I hope to know if anyone know how to snapshot a runtime mashup into an image, if there any extension that can snapshot a mashup and save it in the File Repository?
Hope someone can advice me!
Thank you!
Newbie Kek
You probably need to start a new thread with that other question.
from what i understand, there is indeed some compatibility issue with the pdf extension, not sure what they will be doing to resolve that (if at all).
l believe that unfortunately is a bug, not sure when that will be fixed.
You could define that Query separately in another widget and bind it in.
Maybe a text box, expression widget or a datafilter widget could hold that definition.
Thank you PaiChung!
I cheated using GetDataTableEntryByKey to get my filter data out.
Thanks for info.
Not sure if anyone can advice on capture RunTime Mashup as Jpeg/image.
I used PdfExport in the previous version, but i cannot get it work in the new version...so i am looking for alternative way. Hope anyone can advice me !!
Thank you.
Best regards
Newbie Kek
