I want to change the scrollbar style
BR_10233040
Hey everyone !
I am design a good loking ui interface, anyone know if it's possible to change the color/style of the scrollbar in the mashup ?
here is a screen of my front-end application :
I did tried to add the following code in the custom CSS:
body * ::-webkit-scrollbar {
width:5px;
height:10px;
/* Track */
body * ::-webkit-scrollbar-track {
background:#3c6380;
/* Handle */
body * ::-webkit-scrollbar-thumb {
background: #12243a;
 but I got no change from it. I did noticed however when running the application on firefox, all the scrollbar were actually dark (I don't know why) so as it is not meant to be a deployed app but more like a demo project, I'll use firefox for it instead of Chrome.
For user that wants to make dark ui, it would be very appreciated to be able t change scrollbar easily through Thingworx.
8 REPLIES 8
Hey thanks for your reply !
I checked the documentation already but what i want is "change the color/style" of a scrollbar, no removing it or disabling it which is what your link is referring about.
Thanks again,
B.
just saw that:
width:5px;
height:10px;
/* Track */
background:#3c6380;
/* Handle */
will test it, ty !
Hi @BR_10233040 ,
pls let me know if this works for you.
Bhawna
So I tried to add the code mentioned above in the custom CSS section in my style name called DarkTheme but it doesn't work.
However; I noticed  by switching from chrome to firefox that the scrollbar appears in darkmode in firefox even without code (the built in darkmode of firefox has nothing to do with it) .
From what I understood the webkit-scrollbar is not directly related to thingworx so I don't know if something must be done to apply it in a thingworx mashup.
I have a half-working solution - using firefox but I still would like to know if someone knows exactly what to set to change the color of scrollbar.
B.
Hello @BR_10233040 ,
Pls check the given link:
https://developer.mozilla.org/en-US/docs/Web/CSS/::-webkit-scrollbar
Also you can only change in the Chrome browser only.
P.S. It is NOT advisable to use such features on PROD environment as it is not a standard supported feature.
Bhawna
width:5px;
height:10px;
/* Track */
background:#3c6380;
/* Handle */
Hey @bchaudhary
What you did for changing the color of dropdown scrollbar? Which CSS have you used?
Can you please tell me.
Thanks and regards,
Nilam
