How to reduce size of scrollbars
  • March 25, 2021
  • 4 replies
  • 2225 views
Is it possible to reduce size of scrollbars ?
I have attached image below in that Menu`s scrollbar is bigger .
how to reduce the size of scrollbar ?
Best answer by SachinSharma
@sanjanabalaji
Following help center guide explains how you can configure container scrolling.
Sachin
Support
March 25, 2021
Hi @sanjanabalaji
What are you comparing it to?  There's only 1 screenshot here.  Does the screenshot you provided depict what you want to see?  How are you building the menu?
Do you see the same with different browsers?
--Sharon
@sanjanabalaji
Sachin
Hi @sanjanabalaji
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Toolika Dixit
9-Granite
April 29, 2021
Place this css in custom-css tab in Mashup
you can change the color and size of the scroll bar too...it worked for me.
body * ::-webkit-scrollbar {
width:5px;
height:10px;
/* Track */
body * ::-webkit-scrollbar-track {
background:#3c6380;
/* Handle */
body * ::-webkit-scrollbar-thumb {
background: #12243a;
