I have written an installation script to ease the process of installing ThingWorx Platform 7.4 on Ubuntu 14.04LTS
The script can be found here: Installation script to install ThingWorx Platform 7.4 on Ubuntu Linux 14.04 LTS · GitHub
Currently the script supports the following platform versions:
The script also supports installing free LetsEncrypt Signed certificates as part of the install process.
Alternatively, you can also find instruction on installing LetsEncrypt for ThingWorx here: Install a Free SSL Certificate from Let's Encrypt in Thingworx
Please note that this is a work in progress and as and when time permits, I plan to support:
Any assistance and feedback is always welcome.
Thanks! I'll set up a VM and try it out.
Thanks Craig,
It is a work in progress, so please feel free to add suggestions and correct any bugs.
I am considering looking at the RHEL version any comments?
Here's an unofficial one for Redhat/Ubuntu (attached at the bottom):
this script is great! I made version that works for thingworx 8.2 (attached). Tested on Ubuntu 14.04 LTS with GUI. This will install using port 80 instead of 8080 when using -i parameter. also, if you place your license.bin in the working folder it will automatically copy that in before starting thingworx.
thanks again.
Can you host the file on a different location? I dont have permissions to the PTC sharepoint. Thanks
sure - here you go - https://www.dropbox.com/s/iy0q9wrk4wcvwdy/installer.sh?dl=0
Nice, thanks for sharing, do you think this will work in Ubuntu 16.04 as is?
Hello, the link of "Install a Free SSL Certificate from Let's Encrypt in Thingworx" redirects to "Derivatives with respect to vector components"
@qngo I have corrected the relative link. Please try again and advise, Thanks, Leigh
Thank you, it works
