Issue with PostgreDBSetup
SamuelRodrigues
7-Bedrock
Where do I run this command?
Re:  post
Hi @SamuelRodrigues.
If you ran the script more than once, you may have already created the tablespace.  Would recommend dropping the thingworx database and tablespace and starting over.
--Sharon
You would run it from the command prompt.  On which platform are you installing?
--Sharon
I was able to execute the command entering the folder where the .bat is located. But he is returning this error to me.
--Sharon
slangley
(To:slangley)
Since this issue was resolved via a case, please mark the Accepted Solution here for the benefit of others with the same question.
--Sharon
