Sep 22, 2016 10:22 AM UTC
Issue with PostgreDBSetup
I'm trying to install Thingoworx 7.1 and I have installed postgreSQL 9.4.8.1 that i got along with the installer and the Database user login was also created as twadmin.
When i configure and execute the thingworxPostgresDBSetup.bat script, i end up with the below error
I had highlighted the way i execute the scrip in yellow colour. I had also attached the batch file that I'm executing in this post. Can someone help me out?
Thanks in advance!
Amarkarthi.
Sep 23, 2016 1:39 PM UTC
Hi Arasan,
Here are below some basic troubelshooting tips when installing Postgresql DB for ThingWrox. I hope this helps:
  • Ensure 'ThingworxStorage', 'ThingworxPlatform' and 'ThingworxPostgresqlStorage' folders are created
  • The folders have to be present in the root directory unless specifically changed in any configurations
  • Recommended to grant sufficient privileges (if not all) to the database user (twadmin)
  • Note: While running the script in order to create a database, if a schema name other than 'public' is used, the "search_path" in "postgresql.conf" must be changed to reflect 'NewSchemaName, public'
  • Grant permission to user for access to root folders containing 'ThingworxPostgresqlStorage' and 'ThingworxPlatform'
  • The password set for the default 'twadmin' in the pgAdmin III tool must match the password set in the configuration file under the ThingworxPlatform folder
Best Regards,
Amine
aarasan-21-VisitorAuthor
Sep 27, 2016 10:53 AM UTC
Hi Mohamed,
Thanks for your reply.
Can you please elaborate what do you mean by the below line?
I have installed just the Postgresql in the default location which got installed into C:\Prgoramfiles\postrgresql\ and I created a directory in the name 'ThingworxPostrgresqlStorage' in the root of C drive and given all permissions.
Should i create the other 2 directories as well?
Thanks in advace!!
20-Turquoise
Feb 23, 2017 2:15 PM UTC
Please see this document for some possible solutions: Frequently Seen Errors upon launching the Thingworx application:
Feb 23, 2017 8:46 AM UTC
hi,
please  open your thingworxPostgresDBSetup.bat file and replace tablespace_location to your real location。
such as:
SET tablespace_location=E:/ThingworxPostgresqlStorage
then clean your old operation and double click thingworxPostgresDBSetup.bat。
Best Regards,
zero
Jun 9, 2017 7:30 AM UTC
1. Give all permission to the folder (C:\ThingworxPostgresqlStorage)
2. Use the following command below:
  thingworxpostgresDBSetup.bat -a postgres -u twadmin -l C:\ThingworxPostgresqlStorage
3. Result:
Jun 16, 2017 1:47 AM UTC
Do you make a directory (ThingworxPostgresqlStorage)?
