I have a list which selection I want to specify on load using the "isSelected" property, as well as a validator and an expression. However, this only works for the first row of data returned by my service, is there a way to iterate over the returned data in the mashup so that my validator checks all rows of returned data?
returned infotable
validator checks it isSelected is true
if isSelected is true, expression takes selected property
selected property is set as selectedText in list
list with specific selection on load
Hi @jorgeporras.
Based on our understanding of your issue, you would use the SelectedItems property in the List widget to set the selected row. Here is a link to more information on the List widget.
If you have additional questions, please provide more information on your use case.
--Sharon
Hi @jorgeporras.
--Sharon
Hi @jorgeporras.
Please let us know if you found a solution to your issue. If the previous response allowed you to solve it, please mark it as the Accepted Solution for the benefit of others with similar questions.
--Sharon
