Java SDK Questions
wshih
6-Contributor
Java SDK Questions
Hi All:
I used Java SDK to connect to ThingWorx.
But I always got a error message.
java.util.concurrent.TimeoutException: Timed out APIRequestMessage [requestId: 5, endpointId: 0, sessionId: 20, method: PUT, entityName: anomalytest02, characteristic: Properties, target: *]
	at com.thingworx.communications.common.endpoints.CommunicationEndpoint.sendRequest(CommunicationEndpoint.java:533)
	at com.thingworx.communications.common.endpoints.CommunicationEndpoint.sendRequest(CommunicationEndpoint.java:496)
	at com.thingworx.communications.client.BaseClient.sendRequest(BaseClient.java:1076)
	at com.thingworx.communications.client.BaseClient.writeProperties(BaseClient.java:533)
	at com.thingworx.communications.client.BaseClient.writeProperty(BaseClient.java:474)
	at com.thingworx.communications.client.BaseClient.writeProperty(BaseClient.java:446)
	at org.lsa.TwxSimulator.SimpleThingClient.main(SimpleThingClient.java:110)
I used PTC's simple code.
CRArko
(To:wshih)
Hello. Thanks for posting in the Community.
That timeout error may indicate:
  • There may be some hardware or software issues which may cause the edge devices response time bigger than the allowed time in ThingWorx
  • ThingWorx will throws timeout error although edge devices are trying to response in a longer time
What you might try doing is:
  • Go to Subsystems > WSCommunicationsSubsystem > Configuration
  • Set Amount of time a request will wait for the response message before timing out (secs) (30 secs by default) to be a larger value
Let us know if changing the timeout value makes any difference.
Thank you,
-- Craig A.
4 REPLIES 4
CRArko
(To:wshih)
Thank you,
-- Craig A.
wshih
6-Contributor
(To:CRArko)
Thank you.
I added more resource for hardware and I thought it solved the problems.
But I have a question.
I usually use the http to send or get data for ThingWorx.
Sometime 1 second has 1 ~ 3 requests into ThingWorx
The ThingWorx work well.
Now, I try to build a remote thing to do that.
It's sometime failed.
Does remote thing need more recourse?
VladimirRosu
(To:wshih)
Is the ThingWorx hosting Operating System following the Minimum HW System Requirements at the moment?
wshih
6-Contributor
(To:VladimirRosu)
Oops, It's not follow the server requirements before.
But now, I change it.
