I've tried this solution https://community.ptc.com/t5/ThingWorx-Developers/keytool-error-java-lang-Exception-Input-not-an-X-509-certificate/td-p/623652 but the thingworx foundation installer won't accept the certificate file created.
Any ideas?
Hi Sharon,
Thanks for your suggestion, it works as far as resolving that certificate error, but when I start thingworx foundation by going to https://localhost:8443/Thingworx in chrome an unsafe connection warning is shown. I can login and connect to Thingworx but the connection is unsecure.
Chris
Hi @Chris-P.
If one of the previous posts answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community.
--Sharon
