Kepware tag quality BAD in Thingworx
SathishkumarC
6-Contributor
We connected the kepserver with Thingworx. And fetching few tags from kepserver. After some time in kepware the tag quality is GOOD but in Thingworx the tag quality is BAD. What will be the root cause of this issue?
Thanks.
Are the values changing?
If values are not changing I would check Thingworx VTQ it may not be receiving an updated push from kepware.
Scenario would be.
Kepware starts up, has some value but a problem reading the register, sends a value with quality bad
later it reads the value but value is the same, quality in kepware goes to good, but since value didn't change, nothing is transmitted to Thingworx
@SathishkumarC  I just wanted to follow up with you to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question. If you are still experiencing issues, please do let us know your questions or concerns.
Vibhuti
