Placed a Line Chart on the Mashup, as soon as Chart Plotted, the chart is not getting placed properly on the dashboard.
May be this is due to the Padding issue. The Line chart on the dashboard is something like this:
How Can Padding properly set for the Line Chart.
@paic @slangley @c_lowy @VladimirN
Shashi
The issue is solved by the CSS provided by @c_lowy .
ptcs-chart-line::part(chart-layout) {
padding: 0;
If there are 2 or more DataSources given to the Line chart,
1. Enable the Multiple Data source Visualization option in widget properties, and
2. Connect to the 2 or more Data Sources to chart widget again.
3. Select the X Axis as TimeStamp(in my case)
Shashi
Hi @pshashipreetham ,
Kindly check the below attached article:
https://www.ptc.com/en/support/article/CS343992?posno=1&q=line%20chart%20padding&source=search
Revert back in case of further challenges.
Regards
Bhawna
Hi @bchaudhary ,
tried the article, didn't help. The Picture in the issue posted is after trying out the article you have shared.
Shashi.
Have you provided values for the properties "XAxisMaxmumValues", "XAxisMinimumValues", "YAxisMaximumValues" and "YAxisMinimumValues". These properties can be bound to services if the X Axis values change based on other issues.
Hope this helps.
Hey Hi @PEHOWE
Thanks for quick response, as per the use case the X and Y axis should be auto can't put min and max values.
Shashi
make the container fixed height
Hey Hi @GuruPrasad1 ,
Didn't get you, can you show a example ?
Shashi.
Hi Shashi,
Usually this happens when the container in which your are placing the chart is responsive, if you instead choose a fixed length and give a value say 500px this would appear better. This settings you can find in the layout tab am attching
Regards
Guruprasad S
padding: 0;
Shashi
