Loading mashups with data from windchill taking around 5 - 10 mins also sometime.
KSM
My MAshups are getting data from windchill and for loading the data it is taking around 5- 10 mins which is not at all acceptable by customers.
even though for min 10 objects from windchill it will take around 2- 4 mins. so I want to improve the speed of loading data and loading of mashups and kind of performance of my application. please help me out in this.
KSM
S_Rushikesh
(To:KSM)
Hello KSM,
I believe you're getting data from Windchill via wbjects. Check the wbject response time as well as Mashup binding to the appropriate service.
It's possible that Wbject is taking a long time to collect data from Windchill.
Thanks and Regards,
Rushikesh Shrimal
KSM
(To:S_Rushikesh)
Hello Rushikesh,
Thanks for reply.
is there any mechanism to find out these response times and if am not wrong you are talking about objects(Wbject) right.
KSM
KV_9964594
(To:KSM)
i'm also facing same issue, were you able to improve or still same issue.
KSM
(To:KV_9964594)
Hello KV,
I have modified some code in service, reduce the nested services, and also the data from windchill am fetching which ever it is necessary.
thi
