Mashup Loading Errors
rmasoud1
I am having an unusual problem with the mashups in Thingworx.
I have a dropdown list that and navigation widget, where the selection in the list opens a mashup.
For a few Mashups, it works just fine, but for a majority of them I receive an error of the following, "Could not load 'Mashup Name', internal exception 3".
Any suggestions.
Rami
I found my error.
It was due to an extra / in my URL berfore thingworx.
https://192.168.1.1//Thingworx/Runtime/index.html#master=MasterMash&mashup=Home
the correct URL is:
https://192.168.1.1/Thingworx/Runtime/index.html#master=MasterMash&mashup=Home
8 REPLIES 8
jdass
(To:rmasoud1)
Hi Rami,
Which browser are you using? If you are using Internet Explorer , could you try using Chrome or Firefox and let us know if you are facing the same issue?
rmasoud1
(To:jdass)
Hi Janet,
I was using Chrome, but IE was giving me the same result.
jdass
(To:rmasoud1)
What is your Thingworx platform version?
8.0.0.
I can open the mashups fine if the navigation widget is set to new window, but I receive the error when trying to have a popup window.
ytella
(To:rmasoud1)
Hi Rami Masoud,
Could you please try changing the dimensions for  FixedPopupWidth and FixedPopupHeight settings and let us know the result.
Same result as before.
PaiChung
22-Sapphire I
(To:rmasoud1)
1. Result is repeatable? ie always the same mashups that do not work?
2. Anything that the ones that do not work have in common? Spaces/Special characters in the name of the mashup? Responsive vs. Static
I found my error.
the correct URL is:
