Hello Experts,
Multi Selection Combo Box in list widget is not working....I think I am missing in Bindings or configuration. I tested the SQL service with 2 inputs as shown in attached files, but on UI multi selection is not giving me result. This works good for single selection on combo box, but not works when multiple selection is done. attached results in both cases.
if its binding problem, then how should I pass this selected multiple inputs to the next query ?
Hi @GSPatil.
This is a known issue and is being corrected in the following releases:
8.4.11
8.5.7
9.0
--Sharon
Hi @GSPatil.
8.4.11
8.5.7
9.0
--Sharon
Hi Sheron,
Thanks for replying...here little bit confusion with your word 'Being corrected', does it means its sitll in process? if it is the status for correction, at what version I should upgrade right now ? I am using version 8.4.5 and if I upgrade the version to major higher versions, I will have problem with other widgets, since they are deprecated in higher versions.
E.g. Button Bar widget is deprecated
Request to provide your thoughts on it?
Regards;
Ganesh
Hi @GSPatil.
The corrected versions are not yet released, so you will need to wait to upgrade. Once they are released, you can simply apply the 8.4.11 patch until the decision is made to upgrade to one of the minor releases or the 9.0 major release targeted for late June/early July.
--Sharon
