Problem in ValueStream Service QueryPropertyHistory
bYoussouf
While I'm doing some work in order to display remote data in time series chart,
I created valueStream
I defined a Thing with this valueStream to memorize all remote data value ,
of course, all properties are logged on .
but finally when I try to execute  QueryPropertyHistory service ,it return "Unable to Invoke Service QueryPropertyHistory on Testprop : java.lang.RuntimeException: Unable to retrieve entry"
Any explication about this issue ?
bYoussouf
(To:mnarang)
Solved,
As shown in the article
mnarang
(To:bYoussouf)
This generally comes when the data is somehow corrupted, can you please check this - https://www.ptc.com/en/support/article/CS292076
Mukul Narang
bYoussouf
(To:mnarang)
Solved,
slangley
(To:bYoussouf)
Hi @bYoussouf.
If you are satisfied with the solution you found, please mark your previous post as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
