We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Hello I am trying to utilize methods of the "Network" class... Am having some challenges
I have a network called "CustomerNetwork" I am trying to manipulate it through code
one example removing an entity from the Network
my code for this is
Networks['CustomerNetwork'].RemoveFromNetwork('Store5');
when I test this code I get the following error
Wrapped java.lang.Exception: Invalid parameter type for service: [RemoveFromNetwork] on CustomerNetwork Cause: Invalid parameter type for service: [RemoveFromNetwork] on CustomerNetwork..
According to the class reference the parameter type should be string.. I have entered a string in quotes , In previous tries I have passed a string as a parameter and get the same error... I have tried several other methods where I needed to pass a parameter and get similar results
I recommend you use the snippet.
var params = {
name: undefined /* STRING */
// no return
Networks["AcmeVending"].RemoveFromNetwork(params);
As you can see it is using not a String in the Service but a JSON Object.
Many thanks!!
