Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Network class methods
michaele
Hello I am trying to utilize methods of the "Network" class...  Am having some challenges
I have a network called "CustomerNetwork"  I am trying to  manipulate it through code
one example  removing an entity from the Network
my code for this is
Networks['CustomerNetwork'].RemoveFromNetwork('Store5');
when I test this code I get the following error
Wrapped java.lang.Exception: Invalid parameter type for service: [RemoveFromNetwork] on CustomerNetwork Cause: Invalid parameter type for service: [RemoveFromNetwork] on CustomerNetwork..
According to the class reference the parameter type should be string..  I have entered a string in quotes , In previous tries I have passed a string as a parameter and get the same error...  I have tried several other methods where I needed to pass a parameter and get similar results
paic
(To:michaele)
I recommend you use the snippet.
var params = {
  name: undefined /* STRING */
// no return
Networks["AcmeVending"].RemoveFromNetwork(params);
As you can see it is using not a String in the Service but a JSON Object.
michaele
(To:paic)
Many thanks!!
