I am using nested containers to create a Dashboard Mashup. After adding the Layouts and adding widgets to those containers, I am not able to view the elements which I created initially in the composer as well as in the mashup.
Contents above the 'container-19' are not showing in the composer. I am not able to scroll up beyond this.
On viewing the mashup also, I am getting a partial view of the actual mashup. I am not able to scroll up beyond this.
Thanks in advance.
Hi @Vishnu_K
Are you able to provide your dashboard/mashup so we can take a look here? You can send it via private message if needed. Otherwise, we will need to open a case to look into this further.
--Sharon
