Not able to view contents inside Container in Composer as well as in Mashup
Vishnu_K
6-Contributor
I am using nested containers to create a Dashboard Mashup. After adding the Layouts and adding widgets to those containers, I am not able to view the elements which I created initially in the composer as well as in the mashup.
Contents above the 'container-19' are not showing in the composer. I am not able to scroll up beyond this.
On viewing the mashup also, I am getting a partial view of the actual mashup. I am not able to scroll up beyond this.
Thanks in advance.
@CarlesColl @slangley
3 REPLIES 3
slangley
23-Emerald II
(To:Vishnu_K)
Hi @Vishnu_K
Have you tested with different browsers?
--Sharon
Vishnu_K
6-Contributor
(To:slangley)
Yes. I have tried in Firefox, Chrome as well as in Microsoft Edge and I am getting the same partial view of the mashup as well as the composer.
I am using ThingWorx 8.5.4-b222.
slangley
23-Emerald II
(To:slangley)
Hi @Vishnu_K
Are you able to provide your dashboard/mashup so we can take a look here?  You can send it via private message if needed.  Otherwise, we will need to open a case to look into this further.
--Sharon
