Hi
I want to connect OSI PI server with PTC Thingworx for fetching the data.
I found below link for OSI PI-Thingworx Connector.
https://marketplace.ptc.com/en-US/apps/229637/osi-pi-historian-integration-for-thingworx
Is there any other way to connect OSI Pi system to cloud based PTC Thingworx?
Here is an article - "OSI PI Historian Integration for ThingWorx 8.5": https://www.ptc.com/en/support/article/CS316167
Hi VladimirN,
Thank You for your reply.
The article which you shared has mentioned some resolution as below:
Can you elaborate little bit how this can be used for the OSI PI and Thingworx integration?
So the only way is to purchase a 3rd Party tool to connect to OSI Pi?
