On mashup load, how to all select values from dropdown?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi Team,
On mashup load, how to select all values by default from dropdown? and all selected hint text also need to show
Please let me know asap.
- Labels:
Coding
Design
Examples
Mashup-Widget
Troubleshooting
- Tags:
- development
- thingworx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You are using a service to populate the entries of the dropdownmenu? then you can use the same service to select all on load - just bind your output of the service to Data an SelectedItems of the Dropdown menu. No need to create a new service if you have already one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @P_10844769
Create a new service or reuse the service which returns all dropdown values and bind it to Widget SelectedValues Property
/VR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
