Padding in Line Chart
PSB
7-Bedrock
7-Bedrock
Hi all,
I need to modify the padding of the line chart widget in ThingWorx 9.1.3-b593
I have referred this: probable solution , which does not work for me, as it only applies for versions 9.1.5 & above.
Kindly help.
Sujith
-PSB
slangley
(To:PSB)
Hi @PSB.
We're not seeing an issue in 9.3 and above using style properties for the widget--have you tried that?  Another option would be to upgrade to 9.1.5 if you've validated the desired behavior exists in that version.
Can you provide more details around what you're seeing when you try to modify the padding?  Or we can open a case so we can observe what is happening on your screen.
--Sharon
slangley
(To:PSB)
Hi @PSB.
--Sharon
