How do I get evaluation metrics on a separate dataset?
  • June 6, 2023
  • 2808 views
In Thingworx 9, I know that training a model will result in an automatically generated confusion matrix but is there a way to run another dataset through a model that is already trained, and get a confusion matrix on just the new dataset?
@JA_10708351 ,
Are you able to elaborate on your use case here?
You can retrain a model based on updated datasets: https://support.ptc.com/help/thingworx/analytics/r9/en/#page/analytics/analytics_builder/retrain_model.html
You can append an existing dataset by uploading additional data: https://support.ptc.com/help/thingworx/analytics/r9/en/#page/analytics/analytics_builder/upload_additional_data.html
Generate Confidence Models for an Existing Predictive without retraining the Model: https://support.ptc.com/help/thingworx/analytics/r9/en/#page/analytics/twxa_funtionality/generate_confidence_for_existing_model.html
Though the most direct way to train a new model with a new dataset is to upload it and train on that dataset itself.
Neel
Basically, is there a way to train a model on dataset A, but get the confusion matrix of the model predicting on a different dataset B?
@JA_10708351 ,
Essentially, the Confusion Matrix is created at time of model creation.
It is dependent on the data supplied at time of creation, and currently there is no process to guarantee the same confusion matrix for a different dataset/model
The Retraining of the model using Additional Data (info linked in my original comment) would be the closest to your use case.
Neel
